Router Will not run
2 years 3 months ago #304405 by Irritant
Router Will not run was created by Irritant
Hi,  I am using a Bosch router on a new install.
I can't get the actual router to turn on and off. Probotix controller.
Pin 14 "Spindle On" does nothing and if I invert the pin it will not stop.
Thanks!
2 years 3 months ago #304414 by Aciera
Replied by Aciera on topic Router Will not run
I already pointed out in one of your other post about this very same topic that you were missing all spindle related hal entries and I suggested you create a new configuration with a spindle included. Have you actually done that?
2 years 3 months ago #304545 by Irritant
Replied by Irritant on topic Router Will not run
I will do it today and will report back. I have tried using MDI M3 S1000 and it does not run.
Cheers
2 years 3 months ago #304590 by Irritant
Well, I spent most of yesterday at this and I don't appear any further ahead. When I ran Axis on a very similar machine a number of years ago I never saw or heard about HAL. I guess I will keep at it maybe I will get a flicker of light.
Thanks for the help, Ian aka Irritant
2 years 3 months ago #304594 by Irritant
I spoke too soon. I have it turning off and on!
Not sure how this connects to axis however.
2 years 3 months ago #304604 by Aciera
That is the idea of the Pncconf and Stepconf tools. It should create all HAL connections for you, provided the user entered the correct information of course. Once everything runs you should not need to touch any of the config files again.
Time to create page: 0.454 seconds
