- Thank you received: 5
Yes, as long as the cable gets wound up uniformly (ie the coil does not change diameter due to stacking of the cable on the drum).if the joints were cables wrapped around a drum, would it still be appropriate to transform cable length the cartesian coordinates
This is done in the [JOINT_n] section of the ini file. The 'STEP_SCALE' value defines how many steps the motor needs to rotate to move the joint one machine unit (inch/mm).or would you actually resolve that back to stepper motor steps in order to define a cable length?
