Possibility of a Retrofit on Alcor 220CNC
- Krulli_Fräser
- Thank you received: 5
25 Jul 2024 10:22 #305999
by Krulli_Fräser
Possibility of a Retrofit on Alcor 220CNC was created by Krulli_Fräser
Greetings everybody,
I´m Matthias from Germany and have recently bought a used CNC-Mill with a defective Heidenhain iTNC530 control. After a long call with the really supportive folks at Heidenhain there are a few easy tests left for me to run, but everything seems to point to a fault in the control's hard drive. In that case I would not only need a new hard drive but also the parameter list from the manufacturer.
However I am not enclined to spend much time and money on this "old"(2005) controller and have another fault in half a years time. If the control ran fine i would be more than happy to use it.
At first glance into the control cabinet the electronics are all in good order and working condition. The big drives for the servos and spindle appear to be functional and it does not look like someone tried tinkering with the machine before. As I understand it, this machine was sold new to a company which then used it until it faulted out and some time after the company went bankrupt and sold the shop with the machine. Now the new owner of the shop has no interest in this non running machine which is why i got it for a good price considering the mechanical state of everything.
I had thought about the possibility of a retrofit with linuxCNC from the moment i knew this machine had a faulty control.
These are a few key points i had in mind:
-Reuse of all motors and drivers (3 axes, 1 spindle, speed control only with vfd, no gearbox)
-Reuse of the Heidenhain monitor and keyboard (if that is feasable and someone knows how to do it)
-Control of other systems like lubrication and hydraulic pump should be no issue as I see it
As this would be my first retrofit and I have no experience with linux or linuxcnc a lot of hand holding will be required. However I am willing to invest a lot of time and effort into this machine. I hope i can get away with buying only a computer and the Mesa cards, but not any servo drives or other high load components.
I hope I can find a lot of helpful and exerienced people here and make a good job of this retrofit.
Best regards
Best regards
- Thank you received: 2163
25 Jul 2024 11:23 #306006
Replied by Aciera on topic Possibility of a Retrofit on Alcor 220CNC
Most important question is what motor drives does the machine use (ie for axis motors and for the spindle). If the current drives accept either analog or step/dir signal then they are usually fine for a refit. If they use some kind of serial interface then things get difficult.
- Krulli_Fräser
25 Jul 2024 12:54 #306011
by Krulli_Fräser
Replied by Krulli_Fräser on topic Possibility of a Retrofit on Alcor 220CNC
The drives use an analog signal from the control. I was also able to find datasheets and the software to tune these drives online.
- Thank you received: 7461
25 Jul 2024 16:45 #306025
Replied by tommylight on topic Possibility of a Retrofit on Alcor 220CNC
If the drives are analog +-10V, then in this order
Mesa 7i97
Mesa 7i92TM + 7i77
Mesa 7i92TM + 7i85 + 7i83 + 7i84
Mesa 7i96S + 7i85 + 7i83 + 7i84
Mesa 7i97
Mesa 7i92TM + 7i77
The following user(s) said Thank You: Krulli_Fräser
- Krulli_Fräser
25 Jul 2024 17:12 #306027
by Krulli_Fräser
Yes, the signal is +-10V
In terms of number of IO pins, the control currently has 18 digital outputs, 34 digital inputs, the 3 analog axes, an analog signal (also +- 10v)for the vfd and two more analog pins.
The machine has position feedback through Heidenhain glass scales and a 3 axis module with a single output cable. To close the position loop, the data from this 3 axis module must also be read into linuxCNC, right?
@tommylight: are you referring to the mesa cards i would need to run this system?
Also, the machine comes equipped with 3 encoder handwheels on the front of the machine. I think that layout is really slick for manual type work on this machine and general movement compared to pressing buttons at the control. I've read before that with linuxCNC anything is possible if you are willing to tinker with the software and invest enough time, so adding these 3 "Jogwheels" should not be a problem right?
25 Jul 2024 17:50 #306028
Yes i am, just giving you a head start as it seems you are already set on retrofitting it.
I might be a bit quick on the draw since i have done several retrofits already, all use Mesa cards, all other machines i build use Mesa, i have nothing with Mesa, except the experience of never ever failing or any hiccups ever. And the best support on earth. Also, whatever the price of them, i have to pay at least twice since i live in a black hole, but i pay it gladly.
- Krulli_Fräser
25 Jul 2024 18:20 #306029
by Krulli_Fräser
I'm thankful for any input of the many knowledgeable people here. I am currently educating myself on the topic of mesa cards and interfaces. So far I have the feeling that this retrofit will work well given that all 24v relais and the axis/spindle drivers can be used.
Are there any well documented "by the book" retrofits that I can study to see how this is done properly.
Yes I'm pretty much set on the retrofit since I just heard from Alcor's supplier that the parameter list is not available anymore.
- my1987toyota
- Thank you received: 445
25 Jul 2024 20:32 #306033
by my1987toyota
Replied by my1987toyota on topic Possibility of a Retrofit on Alcor 220CNC
I have always found a good search through the linuxcnc manuals to be of great benefit. See link
linuxcnc.org/docs/stable/pdf/
- Thank you received: 5308
25 Jul 2024 21:45 #306036
Replied by PCW on topic Possibility of a Retrofit on Alcor 220CNC
I would note that it would likely be easier
to find a 7I97T than a 7I97.
The following user(s) said Thank You: tommylight, Krulli_Fräser
- Thank you received: 4137
26 Jul 2024 00:22 #306046
Replied by rodw on topic Possibility of a Retrofit on Alcor 220CNC
Mesa Cards have seperte MPG inputs (5 v signal) Often only 2 but I'm sure different firmware can add a third at the expense of some inputds
Ref: linuxcnc.org/docs/stable/html/examples/mpg.html
(Example is Single MPG with multiple axis select but easy to make it for a single axis.)
Time to create page: 0.704 seconds
