- Thank you received: 229
Are you talking about me just using buck converters instead of isolation? Just use my 24V to power everything....? Isnt there a bigger risk for noise and ground loops? I think i would still need to isolate some things... ie. plasma torch. All that said.. I do think i could skip isolation on the servo amps.. As you can see in the photo... I was just 'following protocol' as they say!Fwiw, I'd just toss away that useless isolation and power your kit from the same 'clean' supply your control board is getting. You'll have to clean that up anyway, might as well use the same rail for the scales/probe/setter/switches/all.
Less is more!!
