Seen this after i already replied above.Pardon my ignorance... Based on your comment I presume that the servo tuning is stored in the servo drives?
I have had the understanding that I DO want the LinuxCNC feedback loop in order to make a [more] closed loop system which is more better than having the control completely blind to the position (or loss of position) of the motors.
i have a working setup with mesa 7i95t (step/dir) and Delta B3-L drives. I am using velocity mode and feedback from drive/encoders, so position is kept while disabling the drives. That means you dont have to re-home after powering off, which is useful on long axes.I would think that leaving it step/dir would be the easiest path
and would require few wiring changes. It also would not require
changing the drive setup, tuning the drives or tuning LinuxCNC's
feedback loop.
The only real advantage to an analog setup is that you can disable
the drives without losing position.
