gmoccapy z height after hitting start
2 years 1 month ago - 2 years 1 month ago #310482 by crazycajun
For some reason the tool is always way above the work. Every axis was zero, it homed Z, came down and its very high up. If i rezero Z again, it works as it should. Ideas?
Last edit: 2 years 1 month ago by crazycajun.
2 years 1 month ago #310490 by Aciera
If you zero without G43 'TLO Z' will be zero and once you activate it then the controller will lift the spindle up by the tool length offset (TLO Z) which seems to be set to 1.5 (inches probably).
2 years 1 month ago #310505 by crazycajun
I did have a 1.5" offset added to tool 12, but took it off. Had the same issue still.
2 years 1 month ago #310508 by Aciera
Take a screenshot of the whole screen so we can see what G/M codes are active also if this happens when running gcode then please attach that as well. We're just poking around in the dark like this.
The following user(s) said Thank You: crazycajun
1 year 11 months ago #314308 by darrylb123
Similar issue. Home made router with manual tool change, linuxcnc newbie. machine has been working successfully for 2 years.
About a month ago, the tool started cutting deeper than it should. Initially blamed a mechanical problem and performed many tests.
Today I discovered TLO (as I mentioned, a CNC newbie) and found the -1mm offset was in the tool.tbl file. Had ignored this file up to this point.
The INI file has not changed in the last year. Why had this not been a problem before? I do try to keep linuxcnc up to date, so an update may have triggered it.
1 year 11 months ago #314312 by Aciera
There is no need to change the ini file to get different behavior like this.
TLO can be activated/deactivated through Gcode (G43/G49)
Tooloffsets can be changed through Gcode (G10 L1)
Sounds like you are missing some fundamental concepts of CNC control. Without a sound understanding of Gcode you are bound to get affected by all kinds of pitfalls.
linuxcnc.org/docs/html/gcode/g-code.html
Time to create page: 0.222 seconds
