Machine moves when you stop program in the middle
2 years 1 week ago - 2 years 1 week ago #312960 by btvpimill
A little more information:
When it is moving on its own, I can not hit pause. Also If i Hit power, it does not respond until the move ends, then the power button is "pressed". Actually it appears all of the GUI is disabled until the move ends. But clicks are stored and executed when it stops moving.
If I hit pause then stop, it will still move.
If I hit pause then power off, It will stay still. Then when I power back on no movement happens. This seems like the work around for now.
Last edit: 2 years 1 week ago by btvpimill. Reason: added info about GUI
2 years 1 week ago #312963 by btvpimill
Great news I think!!
It seems to be 1 or more of the commented lines here from ini file. I have tested about 10 times with commented it does not move on stop. Without commented it moves when stop is pressed.
I have no idea why, but at least it seems back to proper. The problem is the lines were added to use easy probe. So is there an issue there?
2 years 1 week ago #312964 by tommylight
It was the "on abort call" causing that, every time you stop execution of a program it calls that routine and does whatever that routine tell it to.
2 years 1 week ago - 2 years 1 week ago #312970 by Aciera
Compress the entire machine config and attach if here. It's really impossible to do more in depth troubleshooting without seeing all the files.
Also try to uncomment one of those lines at a time and see when the bug appears again.
Last edit: 2 years 1 week ago by Aciera.
2 years 1 week ago #312991 by cakeslob
Ive been using the same easy probe as you for the past month or so, and I havent seen this behavior.
github.com/cakeslob/RRW_LAB/blob/main/Li.../remora-xyzRE_ts.ini
We use the same probe stuff, which I havent exactly changed either.
Anyone else wanna chime in, but the thing that stands out the most is 2.7 classic 2.7
github.com/LinuxCNC/linuxcnc/issues/579
2 years 1 week ago #312994 by tommylight
Just went through those issues on github, so thinking out loud here, if the on_abort is used during probing, it really should not be in the main ini file as that is global for the machine and will cause issues during normal use.
There should be a way to use on_abort only during probing routines, and that is strictly whe it should be active.
Shooting from the hip here, but i really do not like it being in the main ini file.
Time to create page: 0.293 seconds
