Help to understand axes directions
2 years 1 day ago - 2 years 1 day ago #313563 by rmavalente
Hello Mates,
i'm having trouble understanding the proper axes directions between machine vs tool directions.
This is the first CNC I'm commissioning.
When the table is moving to the left, closer to the lathe the X should increment?
When the machine is moving toward the light blue wall the Y should increment?
When the table is moving down, closer to the floor, the Z should increment?
I'm setting my home positions and to order to:
1st: Z all the way down, nearest to the floor at value 0.0
2nd: X all the way to the left, nearest the lathe at value 0.0
3rd: Y all the way back, nearest to the wall at value 0.0
Greetings!
Last edit: 2 years 1 day ago by rmavalente. Reason: Typos errors
2 years 1 day ago #313564 by cmorley
2 years 1 day ago - 2 years 15 hours ago #313565 by tommylight
Edit:
Homing should be
Z ok
X oposite
Y oposite
Although with LinuxCNC you can make it home anyway you like and still have 0 at the bottom left side.
Last edit: 2 years 15 hours ago by tommylight.
The following user(s) said Thank You: rmavalente
2 years 22 hours ago #313593 by rmavalente
it did not, I stared a lot over the milling machine picture and just got more confused, I'm missing some concepts
2 years 22 hours ago #313594 by Aciera
That is correct.
The home position is up to you. There is nothing wrong the way you have it.
2 years 18 hours ago #313597 by rmavalente
Im still confused, Mr Aciera is says the first post is correct, Mr Tommy says X and Y are opposite :(, which is correct or what should I set?
Time to create page: 0.234 seconds
