Asrock Q1900M: Unexpected Realtime Delay, but Good Latency Values
1 year 11 months ago #315371 by uvos
Yeah Instantly anytime linuxcnc is run.
I also just tested locally (not headless) and the result is the same.
1 year 11 months ago #315381 by tommylight
1 year 11 months ago - 1 year 11 months ago #315412 by uvos
theres no usefull info in cmdline output.
I reimplemented latency-test directly into linuxcnc using the timedelta hal module and pyvcp.
And now i can see that the latency excursion occurs once exactly every 60 seconds but only while linuxcnc/axis itself is running never when only latency-test or any of the other latency testing programs are run.
linuxcnc just has to be running, it can be totaly idle and the excursion will occure.
Very strange and i dont know what to try from here :(
Last edit: 1 year 11 months ago by uvos.
1 year 11 months ago #315414 by PCW
The problem with the latency tests is that they just test dispatch latency.
it's likely what you are seeing is some kind of resource contention.
1 year 11 months ago #315416 by uvos
That makes sense.
Do you have any idea on how i could maybe debug what its stalling at?
1 year 11 months ago #315422 by tommylight
Time to create page: 0.302 seconds
