Teknic Clearpath SDSK wiring to 7i96s
1 year 10 months ago #316685 by fully_defined
With daisy chaining of HLFB. There's a decent chance that I have erred in some way setting this up. Please take a look!
image missing https://i.imgur.com/Ir6QwQ7.jpeg
1 year 10 months ago #317043 by Teknic_Servo
Hi fully_defined,In reviewing your drawing, we have a few suggestions and clarifications:
  • For the HLFB output: As long as the circuit has sufficient voltage (24VDC will work) and current, HLFB can be daisy chained as shown in our photo below. You’ll need to configure each motor to use the HLFB mode “Servo On”. In this configuration, if any individual motor has its HLFB go low, the “fault input” at the controller would also go low.
  • For the Enable input: All of the motors can be enabled together as shown. Note that with this configuration, you won’t be able to individually enable or disable any of the axes.
  • For ground lines: As it’s not stated in the schematic, note that you’d want to run all of the ground lines back to the controller and connect them together at the controller (you wouldn’t connect the grounds together at the motors or elsewhere in the cable run).
- Aaron B. Teknic Servo Systems Engineer
1 year 2 months ago - 1 year 2 months ago #333933 by maruf1777
Hi Im Switching to Mesa7i96S and Clearpath SDSK Servos. Did u end up wiring each EN separately as was recommended by ClearPath?. And please can u share your final diagram
Last edit: 1 year 2 months ago by maruf1777.
Time to create page: 0.413 seconds
