7i96s Replacement Needed
  • IronManDylan
  • Topic Author
  • Premium Member
  • Premium Member
1 year 9 months ago #320886 by IronManDylan
7i96s Replacement Needed was created by IronManDylan
I was working on my CNC mill with EDM attachment tonight when a short seems to have taken out my 7i96s.  The machine was never really grounded properly and a drill was laid across from the hot side of the EDM to the rest of the machine.  When this happened everything turned off and now the board is kind of ticking on briefly then immediately back off.  About once a second. The steppes are kind of stepping once when this happens.
I assume that I need a new board.  Of course mesa is out of the 7i96s right now.  Idk how long they will be out.  Does anyone have any suggestions? Is there another board that is a good alternative to the 7i96s? Is there a reseller of these boards? Does anyone have one they would like to sell or get rid of?
  • Moderator
  • Moderator
1 year 9 months ago #320910 by tommylight
Replied by tommylight on topic 7i96s Replacement Needed
Try also
www.mesaus.com
Replacements:
7i76E
7i95T
7i92TM + 7i76
7i92TM + 7i85S
1 year 9 months ago #320915 by PCW
Replied by PCW on topic 7i96s Replacement Needed
Also, if you are not using the analog output, a 7I96 will replace a 7I96S
  • IronManDylan
  • Topic Author
  • Premium Member
  • Premium Member
1 year 9 months ago #320922 by IronManDylan
Replied by IronManDylan on topic 7i96s Replacement Needed
Thank you Tommy.  PCW, is analog out controlling spindle RPM?  If that is the case then I will need the 7i96s.
1 year 9 months ago #320924 by PCW
Yes, spindle control is the typical use of the 7I96S analog output.
Time to create page: 0.160 seconds
