Modify AXIS GUI
1 year 8 months ago - 1 year 8 months ago #322671 by noqui
Replied by noqui on topic Modify AXIS GUI
Thanks a lot cmorley!!! Great Help. Definitely I must study that doc. It has part of what I am looking for.
The last 3 questions I have is: I download from the github a copy of Linuxcnc to a folder in my pc. 1) Then I saw it says in that page: "There are several builtin HAL panels available. In a terminal type qtvcp list to see a list." => If I open a terminal and type this nothing happens 2) How do I start building my Qtvcp ? and 3) How do I start my linuxcnc version instead of the preconfigured version?
I think that maybe part of what I am asking is on linuxcnc.org/docs/html/gui/qtvcp.html#sec:qtvcp-overview suggested page by Hastrh2o
Thanks a lot,
Last edit: 1 year 8 months ago by noqui.
1 year 8 months ago #322745 by Hastrh2o
Replied by Hastrh2o on topic Modify AXIS GUI
Yes, you will find most answer in the doc. I suggest you to install the complete linuxcnc distrib (it can be done in a virtualbox to use it as a sandbox) to focus on your interface test. Here you can load a simulation example and then modify yourself the different files (some of them are duplicated in your home directory).
The following user(s) said Thank You: noqui
1 year 8 months ago #322928 by noqui
Hi, If I only want to add the Camera in the AXIS.GUI, I need to set again all the instructions in the Qt Designer? Or there is a simplified way? Thanks a lot.
1 year 8 months ago #322935 by cmorley
Replied by cmorley on topic Modify AXIS GUI
If you want to edit the panel that has the camerra, using Designer is best.
It's possible to hand edit the .UI file but very error prone.
1 year 8 months ago #322936 by cmorley
Here is a camera only panel. Well it still has crosshair - is that ok?
1 year 7 months ago #322975 by noqui
I have installed Qt Designer,
How can I edit the pre installed panel ? I am not sure where is the file?
Thanks a lot
Time to create page: 0.099 seconds
