connections for 7i97t
1 year 7 months ago - 1 year 7 months ago #323644 by dlc mnl
What connections does the 7i97t board need to servo motors to operate?
(as+, da+) analog command voltage,
(gnda, da ground) analog ground,
(SON) servo enable,
(rdy) servo ready,
(oa+)A+
(oa-)A-
(ob+)B+
(ob-)B-
(oz+)Z+
(oz-)Z-
Last edit: 1 year 7 months ago by dlc mnl. Reason: error of image
1 year 7 months ago #323647 by PCW
Replied by PCW on topic connections for 7i97t
7I97T     DRIVE CN1
AOUTN   AS+ (26)
GND       GNDA (11)
ENAN+  SON  DI1 (16)
ENAN-    24V Common
INN         RDY  DO1 (20)
INCOM    +24V  (Drive output common 24V common)
QAN+       OA+  (13)
QAN-         OA-   (28)
QBN+       OB+  (14)
QBN-         OB-  (29)
QIDXN+    OZ+ (15)
QIDXN-      OZ-  (30)
1 year 7 months ago #323652 by dlc mnl
Replied by dlc mnl on topic connections for 7i97t
Is z encoder output signal and encoded signal to ground needed?
1 year 7 months ago #323709 by PCW
The "Z" signals are needed if you want to home to index.
(for more accurate homing)
Yes, normally you would connect the encoder ground at both the
drive and 7I97T end.
1 year 6 months ago #326549 by dlc mnl
Is rdy needed?
1 year 6 months ago #326551 by dlc mnl
Hello, what connections are needed for the 7i97t?
I have this spreadsheet, and these are the connectors.
has no rdy
Time to create page: 0.242 seconds
