ENCODER_RATIO function implementation.
1 year 6 months ago #326341 by timo
I am hobbing without any special UI for a while now. I change invert.0.in pin manually. There are some other parameters that I would have to change manually, when using "additional" rotation for Pfauter method. But I barely touched this, mainly because of mechanical setup issues.
I really would (should) give it another try, but my patience was not high enough. I am interested in improving the situation on my machine.
@boogie, please keep us update how it is going. :-), maybe I can finally get there.
As I understand it the UI that Andy made runs as "sub window" in the Axis UI and provides the special inputs and some features.
Greetings Timo
1 year 6 months ago #326350 by andypugh
Yes, mainly the UI does the gear size / depth calculations and gives you a span measurement to run a quick test that the tooth depth is correct.
It could be more aesthetic:
The following user(s) said Thank You: timo
1 year 6 months ago #326508 by timo
Thanks for the screen shot.
I think it looks "good enough" (at least for me :-) using it for DIY hobbing of "toy gears" )
Do I understand this right that a G-code file is generated based on the input data to run the process?
Does "shift" button refer to profile shift or is it doing a hob shift? (tangential hobbing :-O )?
Greetings Timo
1 year 6 months ago #326584 by andypugh
There is a fixed but parametric G-code file as part of the config that does the feeding / multiple passes.
You should definitely look at that file to see what it does, and also what it assumes. The system assumes that the tip of the cutter is touched-off to the workpiece radius (ie Z = 0 is on the work axis)
Also note that the axis assignment is a little unusual, with hobbing radius as Z and work axis along X.
"shift" is a profile shift, simply a radial offset of the hob relative to the workpiece centreline.
Time to create page: 0.390 seconds
