- Hardware & Machines
- Driver Boards
- Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi
- AdelRTP
20 Jun 2025 15:04 #330578
by AdelRTP
Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi was created by AdelRTP
Using with a Mesa 7i76EU (IP ). Ping works, but:mesaflash --device 7i76eu --addr 192.168.1.121 --readhmid
Unsupported ethernet device 7I76EU at 192.168.1.121
No 7I96S board found
Also tried with IP after moving jumper W14 up
mesaflash --device 7i76eu --addr 10.10.10.10 --readhmidIs the 7i76EU supported? How to fix "Unsupported device"?
mesaflash 3.4.9
192.168.1.121
Also tried with IP
10.10.10.10
Unsupported ethernet device 7I76EU at 10.10.10.10
- Thank you received: 6925
20 Jun 2025 15:57 #330582
Replied by tommylight on topic Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi
Use the latest version of mesaflash
github.com/LinuxCNC/mesaflash
Scroll down for info on how to install.
The following user(s) said Thank You: AdelRTP
- AdelRTP
20 Jun 2025 19:39 #330590
by AdelRTP
Replied by AdelRTP on topic Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi
thanks a lot Tommy,
i’m trying to control two servo drives (Modbus RTU) with a Mesa 7i76EU in LinuxCNC, but I can’t use Classic Ladder or PktUART
20 Jun 2025 19:56 #330592
Moved to "driver boards" section.
- Thank you received: 4966
20 Jun 2025 20:08 #330594
linuxcnc.org/docs/devel/html/man/man1/mesambccc.1.html
linuxcnc.org/docs/devel/html/man/man9/hm2_modbus.9.html
Replied by andypugh on topic Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi
Have you spotted the new Modbus / PktUART driver? It's more flexible that mesa_modbus. (but only exists in the dev version of LinuxCNC)thanks a lot Tommy,
- AdelRTP
20 Jun 2025 20:34 #330598
by AdelRTP
- Thank you received: 5172
20 Jun 2025 20:49 - 20 Jun 2025 20:50 #330600
Replied by PCW on topic Mesaflash 3.4.9 shows "Unsupported ethernet device 7I76EU" despite successful pi
You would load the 7I76eu firmware that includes PKTUart support
7i76eu_7i76x1_pktv3d.bin
This file is in the 7i76eu.zip archive downloaded from Mesa's store (in the specifications tab)
You program it with mesaflash, something like:
mesaflash --device 7i76eu --addr 10.10.10.10 --write 7i76eu_7i76x1_pktv3d.bin --reload
Last edit: 20 Jun 2025 20:50 by PCW. Reason: sp
- AdelRTP
20 Jun 2025 20:54 #330602
by AdelRTP
where can i find it ?
20 Jun 2025 21:00 #330604
store.mesanet.com/index.php?route=produc...oduct&product_id=399
Click on the specifications tab
- Driver Boards
Time to create page: 0.286 seconds
