Stepper motors should hold position when error.
1 year 1 month ago #335565 by LeonDolnicar
I am running a 3 axis CNC mill with stepper motors, through a 7i76eu card running linux CNC. Currently when one of the motor drivers gets a fault, the motor lose all power. This is problematic for the Z axis, which uses a stepper motor with a brake. When its driver gets a fault the brake is engaged, but there is a delay, in the meantime the z axis is in free fall for about 10cm. Is it possible to program the stepper drivers in such a way that when they get a fault they stop the motors and hold the position.
Thank you for all the answer and suggestions in advance.
1 year 1 month ago #335573 by tommylight
How does LinuxCNC/Mesa know there was a fault?
If drives have fault out, there might be something we can do, but for now i am out of commission as i spent the whole day chasing python scripts to output gcode for 3 and 4 axis machines from some really obtuse files some proprietary software outputs.
1 year 1 week ago #336699 by LeonDolnicar
Faults from stepper drivers are wired as inputs on mesa card. When fault is triggered mesa triggers emergency stop.
1 year 1 week ago #336704 by PCW
Does the drive itself power down on a fault?
1 year 1 week ago #336835 by LeonDolnicar
Yes,
the motor driver detects the fault and sends the signal to the the mesa. When driver detects the fault it also disables the motor (causing the z axis to fall). What I want is for the driver to stop the motor and hold position when it detects a fault not disable it.
1 year 1 week ago #336836 by PCW
Can you change the drives disable behaviour?
If not, is there a way to reset the drive?
Time to create page: 0.380 seconds
