Changing starting point on 2D job
  • kb58
  • Topic Author
  • Junior Member
  • Junior Member
1 year 1 week ago - 1 year 1 week ago #337265 by kb58
Changing starting point on 2D job was created by kb58
I'm using LinuxCNC as part of a wire EDM, and it's also my first experience with Linux of any sort.
When I load a job, a 2D representation appears on the Preview tab and on the figure is an "X", where cutting will start. Depending upon the shape of the blank and the outline of the part, it's sometimes better to have the starting point elsewhere. Is this something that can be changed within LinuxCNC, or can it only be done in the program that generated the G-code file (Vcarve, in my case)?
Last edit: 1 year 1 week ago by kb58.
1 year 1 week ago #337291 by tommylight
Replied by tommylight on topic Changing starting point on 2D job
Not what you asked, but try Inkscape, it is free and it exports ready for use gcode, and more importantly very easy to use and add a line for were you want the cut to start.
Vcarve is really, really not for EDM, as far as i am concerned.
The following user(s) said Thank You: kb58
  • kb58
  • Topic Author
  • Junior Member
  • Junior Member
1 year 1 week ago - 1 year 1 week ago #337293 by kb58
Replied by kb58 on topic Changing starting point on 2D job
Huh, shows what I know - I'll certainly check out Inkscape!
To be clear, I use Alibre for CAD and borrow Vcarve's vectoring feature to convert it to G-code with my own post-processor.
Time to create page: 0.046 seconds
