Delta Servo ASD-B2,
  • bevins
  • Topic Author
  • Platinum Member
  • Platinum Member
11 months 4 weeks ago #337883 by bevins
Delta Servo ASD-B2, was created by bevins
Hi ,
I am looking for some help with this drive. I had one go bad and trying to get a new one up and running.
If someone can help with this drive please let me know.Had a drive go bad and got a new one on ebay and cant get it to act right.
Thanks,
Bob
11 months 3 weeks ago - 11 months 3 weeks ago #338020 by Todd Zuercher
Replied by Todd Zuercher on topic Delta Servo ASD-B2,
I'm afraid we really don't have enough information to help you.
We have to assume that the new drive isn't configured the same as your old one. Are both the new and old drives the same model and version? (There are different models of Delta Servos that are the same size and look simular, but the motors from an older one are not compatible with a newer drive or vice versa.)
Do you have a back up of all of the parameters from the old drive? Assuming that your new drive is the same model as the old one, you would need to load the parameter settings from the old one to the new one in order for it to behave as before. If you don't have either a software backup of the parameters, or written down paper copy of the parameter settings, then you will have to figure out what they need to be. We can't really help you with that though unless you tell us how the motor/drivev is mis behaving.
Last edit: 11 months 3 weeks ago by Todd Zuercher.
Time to create page: 0.040 seconds
