The Current Bread & Butter Setup?
11 months 2 days ago #339508 by Billy Boy
I'm looking for suggestions for a simple bread & butter Linux CNC install.
It seems like an Raspberry Pi 5 + Mesa 7i96S might be the current standard, but it's not super clear? A while back it seemed like the Beaglebone was a good option, but it seems things have not gone that way?
Background...
I've built/retrofitted a number of machines with Linux CNC, but not for perhaps 10 years.  I've done a lot of machining and I'm fully competent with Linux.
I've got a new project that wants to integrate 2 Sherline CNC chucker lathes with some additional widgets.  Each lathe would get its own LinuxCNC hardware & software and the integration would be via ssh/linux command line.
If I can get the system working well, I might get orders for 10 or 50 of these systems over the next few years, so I would really like to use a stable, easy to get, standardized off-the-shelf parts, that can be expected to remain available for the next 5 years. I'm *not* looking to cobble something together out of 10 year old PCs, and I'd prefer not to build on some wierd/cheapo/legacy PC off Amazon which may go away in 3 months.
I'm looking for a simple reliable bread & butter LinuxCNC platform.
Suggestions?
BB
11 months 2 days ago #339509 by andypugh
For reproducible hardware the Pi5 is probably a good choice. It's not the absolute best of platforms, but it is a known quantity and that would be useful if you are making multiples of the system.
11 months 1 day ago #339535 by Billy Boy
Thanks Andy.
Is the rPi GPIO interface considered fully baked, or is the Mesa 7i96S the smart bet? I would totally love to avoid the $150+ for the Mesa, but only if that does not then cost me an additional $300 in labor time.
BB
11 months 21 hours ago #339543 by unknown
Put it this way, if the RPi5 goes bad for whatever reason, you'll have to get a new Raspberry whatever, but if you go with the 7i96 any machine with an Ethernet Port will slip in, copy your config over and you're good to go. Hardware step generation, Mesa, et al, will be smoother than software step generation.
11 months 18 hours ago #339545 by Billy Boy
Huh... I've not experience a properly powered and cooled rPi going bad. Maybe I've been real lucky?
Does the Mesa support tighter step timing accuracy than the "base thread" step generator?
I was not aware that the Mesa gave improved performance? Is there a reference-able document that gives a *quantitative* analysis of this performance gain?
Thank you,
BB
11 months 17 hours ago #339549 by tommylight
In short:
RPI can do at most 20000 steps per second, if lucky and with a bit of fiddling (this is from what i read here, i stopped using RPI since version 3B)
Mesa can do 10000000 (10 million) steps per second on any or all pins, if pushed, does 1-4 million for years on end, can use any pin as input or output, does steps, encoder counts, PWM, on any pin (the FPGA part), can be programed as needed, extremely reliable (i have over 80 or 100 or i have no real clue in daily use on industrial machines weighing several tones without a single issue ever for many years), and by far the best support on planet earth in the form of PCW.
Yes i am biased, from experience, no i am not payed by them, and yes any price you see for Mesa boards i have to pay at least twice that, and i pay it gladly for the piece of mind i get with them, i can sleep calmly without worrying something might fail.
As for RPI, i personally use old "enterprise" PC's and some laptops, so if you can find such things it is another alternative, i can get Lenovo T470 for 120-150 euro, with 14" touchscreen, battery, plenty of RAM and NVME, with built in network jack, for me this is much cheaper than any RPI combo and more powerful and usable.
Time to create page: 0.253 seconds
