pocketing program
- 858PSJ
- Thank you received: 9
17 Mar 2026 19:44 #344428
by 858PSJ
pocketing program was created by 858PSJ
I have written a pocketing program using g-codes, it pockets triangles, rectangles, trapezoids and some unusual shapes. the attachment has a screendump of eight different ones. The program is available as a .ngc file and runs on linuxcnc/axis version 2.6.13 on ubuntu 12.04 LTS 32 bit (using the rtai kernel to operate a Taigtool mill through a xylotec controller.) I would like to donate this program to the site if there's any interest) my email address is This email address is being protected from spambots. You need JavaScript enabled to view it.
the program is 580 lines long and includes 112 lines of sample polygons. it uses "o" codes a lot.
The following user(s) said Thank You: tommylight, onceloved, saxa
- Thank you received: 7478
17 Mar 2026 21:08 #344429
Replied by tommylight on topic pocketing program
You can zip the program and attach it to the original post here.
Or make a new post as the editor likes to mess formatting.
- 858PSJ
18 Mar 2026 17:53 #344475
by 858PSJ
Replied by 858PSJ on topic pocketing program
here's a screenshot and a pocketingprogram
- 858PSJ
26 Mar 2026 18:51 #344793
by 858PSJ
Some think that circles and ellipses are polygons as well. So I added a ellipse pocketer subroutine (which does circles too) to the program, and here it is, I also "sharpened up" the vertices of the polygons a bit. See the screen dump for how well the "half ellipse" fits with the square.
- 858PSJ
04 Apr 2026 12:21 #345157
by 858PSJ
The attached screenshot of a 20 tooth pocket shows a larger view of the program operation. It runs by drawing nested figures inside each other by shortening (or lengthening) each side of the figure while drawing it. The shortening (or lengthening) values are recorded in a table as they are encountered when the figure is first executed. A multiple of the values is used for each execution of the figure and the values remain constant for the entire pocketing operation. The table starts at memory location 100 and the operators manual says that location 31 to 5000 are "user defined" so we can have lots of sides. Notice that the pocketing operation evolves such that the shown 40 sided figure produces a circular (or 20 sided) area that needs to be Pocketed to complete the entire pocket operation. I doubt that commercially available packages (eg autocad) can duplicate this activity easily since they would require an exhausting specification of each nested figure before executing it. G-code's ability to process subroutines allows us to have the figure execute itself here for pocketing purposes. It also gives us the ability to hack individual sides and thereby make really ugly figures.
- 858PSJ
25 Apr 2026 18:29 #345924
by 858PSJ
This was originally supposed to be just a tough shape to pocket, it looks like it could be used for making a saw blade too. The algorithm used to develop the perimeter would be prone to accumulate minor errors into major blunders since it accumulates multiple executions for sine and cosine functions to add up to a complete closed polygon. The verbosity setting prints out the value that is computed by the program to be the "last side". This one had a last side that was .065" bigger than the other 19 teeth. repetitive editing of the apex angle of the 19 teeth eventually resulted in a "last tooth" that was .0015" too small. Verbosity set to 3 dimensioned a bounding box where width was .00065" less than height so the shape is reasonably round, I did draw a circle around the tooth tips and couldn't see any big (or small) ones so when I decide to mill this at least the database will be more accurate than my mill.
I added the circular area inside the part since I had left it unfinished on my previous post, the screen shows the circular path but doesn't show the boundary circle I used to eyeball "roundness", nor does it show the center mounting hole which took a pile of g-code to finish.
the program is still g-code in its entirety, and its gotten pretty Hackey lately.
- 858PSJ
29 May 2026 00:40 #346722
by 858PSJ
In the process of adding the center finding code I discovered a bug in program and fixed it. In the meantime I've added a small amount of g-code to facilitate cutting center holes in the figures. (sorry) Any form that is encoded can be machined out by setting traversals to one and adjusting passesneeded cuttingfeed and cuttingdepth to proceed downward until it cuts the perimeter. This has nothing to do with pocketing aside from the fact that traversals control is needed there. The addition of a center hole makes the program very handy for lots of other stuff. Center hole cutting begins once one pass of the perimeter is milled and cutting the perimeter resumes once the center hole has executed the specified number of plunges which is a subroutineparameter passed in with the original call. I have a screendump of the new stuff which also has the circle/ellipses Do I just dump that stuff here? The centerfinding code draws a reference circle overtop of the figure which makes the screen dump look crowded (see the attached picture.
The following user(s) said Thank You: RotarySMP, tommylight
- 858PSJ
17 Jun 2026 11:59 #347132
by 858PSJ
... It wouldn't take much to change every "plunge" in this g-code program into a "leap" for use on a 3d printer to make floors walls and lids for oddly shaped boxes. I suspect that some 3d printers already do something like this so now all we need to do is figure out how to get g-code to produce annotated drawings (instead of parts themselves) so we can sell the products to our waiting customers?...
- 858PSJ
04 Jul 2026 13:09 #347514
by 858PSJ
Every shape has a variable named cuttingdepth and if one makes cuttingdepth be negative the endmill goes up instead of down so we'll have to replace the endmill with an extruder if we need to make "precise pieplates". we'll also need to add a bunch of g-code to run the extruder, (and the heaters/fans?) . A g-code driver for that should be available from somewhere, Prusa used to be open source, but could be quite large for implementation here, but its something to think about.
- 858PSJ
22 Jul 2026 17:50 #347962
by 858PSJ
This version makes a log file in the /tmp directory (which gets erased upon reboot). Note the logfile entries look somewhat like g-code linear move with line length and tilt appended to its end. the line origin and endpoint are listed for each line in the figure. Copy just the g-code entry into the system clipboard (after displaying or editing the log file in a linux window). Mouseover the MDI execution rectangle and depress cntrl shift and h keys together, the clipboard will be deposited into the MDI history window just above. The g-code can be executed by mouseing it into the execution rectangle and then mousing its go box. This let you re-visit any line in the figure (perhaps to check for interference problems, I use this method to measure saw tooth rake angle) Edit the ngc file to make a logfile in another directory or for another part. (
Manually select the layer you wish to view in MDI by setting depth)
portion of log file:
g1 f 100.000000 z -0.120000
g0 x 2.000000 y 1.000000 len:0.521875 8.000000
g1 f 100.000000 x 2.516796 y 1.072631 len:0.521875 8.000000
g0 x 2.516796 y 1.072631 len:1.939508 105.731904
g1 f 100.000000 x 1.990925 y 2.939487 len:1.939508 105.731904
g0 x 1.990925 y 2.939487 len: 1.939508 270.268096 ....
Time to create page: 0.184 seconds
