Variable input during automatic operation
  • GeneRF
  • Topic Author
  • New Member
  • New Member
7 months 1 week ago #344641 by GeneRF
Is there any practical method to input a variable while a g-code program is running? For example Pause, Request input, Resume, and then use that input.
Currently using 2.8.4 with the Axis interface.
I know multiple ways to change variables when a program is not running, but I have never seen any method for temporarily modifying a running program.
This would allow a single program to process workpieces with different sizes, for example.
I understand this could be dangerous, stupid, or worse. Not planning to be a pioneer.
I searched the forum and the documentation, and I could not find any mention of this topic.
Gene
7 months 1 week ago #344644 by Vegko
Replied by Vegko on topic Variable input during automatic operation
Create a (physical)button, so you can read pin signal, and if 0 do... if 1 do...?
There is no parameter screen where you can watch/change parameters, would be nice do.
Could you elaborate what you want to change while milling?
Only thing i could think of is change off depth?
7 months 1 week ago #344646 by 3404gerber
Replied by 3404gerber on topic Variable input during automatic operation
Found this post,  sounds similar to what you need.
  • GeneRF
  • Topic Author
  • New Member
  • New Member
7 months 1 week ago #344647 by GeneRF
Replied by GeneRF on topic Variable input during automatic operation
As I said, change of workpiece length, or as you say, change of depth.
  • GeneRF
  • Topic Author
  • New Member
  • New Member
7 months 1 week ago #344675 by GeneRF
Thanks! That does it.
