- Thank you received: 44
G64 and G20/G21 handling
- dbtayl
- Topic Author
7 months 6 days ago - 7 months 6 days ago #344891
by dbtayl
G64 and G20/G21 handling was created by dbtayl
How is G64 P- handled internally with G20/G21? Is the P value just a straight number that's interpreted according to whatever units are currently active? I don't see any mention of units at all in the docs.
FreeCAD is changing up its postprocessors, and I'm trying to figure out if
G20
G64 P0.01
G21
is the same as
G21
G64 P0.01
Thanks!
ETA- Now that I look at it, the order is still the same as the old FreeCAD postprocessors, but I'd still like to know. It seems weird to me to see G64 before either G20/G21 appears, but if it's literally just setting a number that has zero unit awareness, it's not actually a problem.
G20
G64 P0.01
G21
is the same as
G21
G64 P0.01
Thanks!
Last edit: 7 months 6 days ago by dbtayl.
- MaHa
- Thank you received: 222
7 months 6 days ago #344892
by MaHa
Replied by MaHa on topic G64 and G20/G21 handling
- dbtayl
- Topic Author
7 months 6 days ago #344908
by dbtayl
Replied by dbtayl on topic G64 and G20/G21 handling
Where are you seeing that? I don't recall seeing the blending tolerance displayed anywhere, though I suspect I'm just being blind.
That answer works well enough for my purposes- regardless of whether that means "always uses mm" or "always uses machine units".
- MaHa
7 months 6 days ago #344910
by MaHa
Axis UI => Machine menu => Show LinuxCNC Status => settings
or from linuxcnc.stat attributes
linuxcnc.org/docs/stable/html/config/pyt...ding_linuxcnc_status
settings
(returns tuple of floats) - current interpreter settings. settings[0] = sequence number, settings[1] = feed rate, settings[2] = speed, settings[3] = G64 P blend tolerance, settings[4] = G64 Q naive CAM tolerance.
settings
Time to create page: 0.117 seconds
