(Solved) G43 not being applied in g-code
- spumco
- Thank you received: 854
28 Apr 2026 15:55 #346014
by spumco
Replied by spumco on topic (Solved) G43 not being applied in g-code
@Andrax
I'll try it, thanks.
@Maha
like @Aciera, I didn't think that was how M6/G43 worked, but I'll try it (again). I've tried putting G43 on the next line after the Tn M6 (or M6 Tn) line, but that didn't seem to make a difference.
@Aciera
Thanks for pointing that out. I think I tried the RETAIN_G43 when I first noticed an issue during the G10 L2 WCS flip testing a couple weeks ago. I know I haven't turned that on/off during this last round of fiddling.
Among the many things confusing me is the F360 post for LCNC turning. right at the beginning of the post file is this:
But the post outputs no G43 at all - neither on the same line or the next. Something to sort out once I get G43 working.
I'll try everyone's suggestions this evening and report back. As usual, I'm grateful for the assistance.
@Maha
@Aciera
var outputG43OnSeparateLine = false;But the post outputs no G43 at all - neither on the same line or the next. Something to sort out once I get G43 working.
- spumco
29 Apr 2026 00:43 #346027
by spumco
Holy #@)(*-balls!!!
Who would have thought RETAIN_G43 = IGNORE_G43?
G43 works on the same line as Tn M6, as well as on the next line.
More work left to do, of course... but after about 3 years I'm finally making chips on this stupid lathe.
Thank you all!
Mods - please marked SOLVED
Thank you all!
The following user(s) said Thank You: tommylight, pommen
- Thank you received: 7337
29 Apr 2026 02:59 #346028
Replied by tommylight on topic (Solved) G43 not being applied in g-code
Done, thank you.
Time to create page: 0.129 seconds
