Trixy Install problems
- aaron
- Topic Author
3 months 4 weeks ago #347610
by aaron
Trixy Install problems was created by aaron
I have downloaded and flashed Debian Trixy Linuxcnc from the download page twice now. And every time I try to install, it gets stuck at configuring the sources. I do not think it is a network problem because when I run the live instance, I can browse the internet. Please can someone offer a solution, or tell me where I can download the Bookworm version, which I know works.
Aaron
Aaron
3 months 4 weeks ago #347616
Replied by rodw on topic Trixy Install problems
You should still be able to install it without internet or broken installer but apt will point to the CD only. I think it will get confused in some locales because the installer defaults the mirror and in some countries, this fails.
There is an issue with Debian Live which we use for the installer. Debian moved to using debian deb822 format for sources. This places the sources in /etc/apt/sources.list.d/debian.sources instead of /etc/apt/sources.list
Debian live has not caught up with this change.
so assuming you do get a bootable system, what does
cat /etc/apt/sources.list display? is it just the CD or DVD?
You could create Debian.sources in the folder above that contains
Then delete /etc/apt/sources.list
and then type sudo apt update
Types: deb deb-src
URIs: http://deb.debian.org/debian
Suites: trixie trixie-updates
Components: main contrib non-free non-free-firmware non-free
Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg
Types: deb deb-src
URIs: http://security.debian.org/debian-security
Suites: trixie-security
- aaron
- Topic Author
3 months 4 weeks ago #347623
by aaron
Replied by aaron on topic Trixy Install problems
Thanks for the explanation, but I still don't know how to install the thing. I have tried all the options at that stage of the process, but it just goes round in an endless loop of errors. If I tell the installer I am in USA might that work?
3 months 4 weeks ago #347651
2.9.10 has been released. Maybe try it.
If the installer fails its on the Debian side (or hardware). I was chatting to an experienced user in NZ just this morning with problems but he did manage to get it working. The ISO he had was working on other PC's.
- Thank you received: 2668
3 months 4 weeks ago #347657
Replied by andypugh on topic Trixy Install problems
We don't have a 2.9.10 .iso yet. I will try to generate one today.2.9.10 has been released. Maybe try it.
3 months 3 weeks ago #347659
Try this image:
www.linuxcnc.org/iso/linuxcnc_2.9.10-amd64.hybrid.iso
- Jens23
3 months 3 weeks ago #347692
by Jens23
Replied by Jens23 on topic Trixy Install problems
I am currently trying to install this and it doesn't validate. When making a bootmedium RUFUS even said, that 1.5GB of the image are missing. Could you please check?
It looks like the 2.9.10 image is half the size of the previous.
- aaron
- Topic Author
3 months 3 weeks ago #347779
by aaron
Thanks for all your replies. However, I found the only way I could do the install was by downloading Debian, doing apt update, apt upgrade, and then installing LinuxCNC via Synaptic. Worked a treat.
3 months 3 weeks ago #347788
That might be a fairly old version of linuxCNC.What is the version number printed on the splash screen? Or in the console if stating from the terminal? current is 2.9.10Thanks for all your replies. However, I found the only way I could do the install was by downloading Debian, doing apt update, apt upgrade, and then installing LinuxCNC via Synaptic. Worked a treat.
Time to create page: 0.060 seconds
