spindle speed pick-up using the bull gear
  • okielaxplyr
  • Topic Author
  • New Member
  • New Member
2 months 3 weeks ago - 2 months 3 weeks ago #348745 by okielaxplyr
spindle speed pick-up using the bull gear was created by okielaxplyr
Hello folks,
Wondering if anyone has incorporated a hall effect sensor in their Bridgeport gear head to pick up real-time spindle RPM.
My plan is to drill and tap a hole to pick-up the bull gear teeth with a hall effect sensor, then wire the sensor into my encoder_4 inputs on a  mesa 7i77.
Is this is viable? If it is what I am looking for is measurements and locations on where to drill/tap the hole for the hall effect sensor, also what sensor do people use for this job? I currently have a ZF GS100502 gear tooth speed sensor good to 15khz.
I have the following hardware:
Bridgeport V2XT {1996) donor mill using the legacy servo motors and drives.
Mesa 7i92M and 7i77D
cheap amazon VFD.
Please advise.
John VanAtta
Last edit: 2 months 3 weeks ago by okielaxplyr.
2 months 3 weeks ago #348765 by skunkworks
Replied by skunkworks on topic spindle speed pick-up using the bull gear
We used gear tooth sensors.... for rigid tapping you would need 3 - a,b and z
Jon from pico systems did the same thing...
pico-systems.com/bridge_spindle.html
Good writeup..
sam
Time to create page: 0.037 seconds
