Mesa 7i96s to Gecko G540 with simple 3 axis Router
1 month 2 weeks ago #349657 by DougS
Hello Folks Newbe here.
I mistakenly though I could easily convert my Shark SD120 to a Linuxcnc setup using a Mesa 7i96s to a Gecko g540. After hours of fooling with it and being misled by AI I now realize there is no easy way to setup the HAL and INI configs. I purchased the hardware and would like to make it work so any help would be greatly appreciated.
Thanks,
Doug
1 month 2 weeks ago - 1 month 2 weeks ago #349662 by PCW
If the G540 is connected to the 7I96S parallel expansion connector, you should use
7i96s_g540d.bin firmware, that configures the 7I96S's P2 expansion connector the G540
pinout, Then basic setup can be done with pncconf. No need for AI, that just a time sink here.
Last edit: 1 month 2 weeks ago by PCW.
1 month 2 weeks ago #349713 by DougS
Thanks for the help, making much progress. New question:
What is the syntax to negate these inputs?
# external input signals
# --- MIN-X ---
net min-x     <=  [HMOT](CARD0).gpio.000.in
# --- MIN-Y ---
net min-y     <=  [HMOT](CARD0).gpio.001.in
# --- MIN-Z ---
net min-z     <=  [HMOT](CARD0).gpio.002.in
# ---setup home / limit switch signals---
net x-home-sw     =>  joint.0.home-sw-in
net min-x     =>  joint.0.neg-lim-sw-in
net x-pos-limit     =>  joint.0.pos-lim-sw-in
1 month 2 weeks ago #349715 by DougS
Thanks for the help. Sending this because I'm not sure I posted my next question in the right way..
Time to create page: 0.099 seconds
