how to get better latency test results
- zjjxxsh
21 Sep 2026 16:49 #349770
by zjjxxsh
how to get better latency test results was created by zjjxxsh
I'm using Simens IPC127e. It's a Siemens's computer working on Intel E3940/4GB and Intel i210 network card. This computer was used for industry control, it should working well with linuxcnc.
I turned off all the turbo mode, C-state,etc. But the latency test shows the jitter is 50-60us. Is it enough for Ethercat control? Is there anything else I need to do with.
Btw, I have no Idea on turn-off the OnBoard Audio, how should I do.
- Thank you received: 7496
21 Sep 2026 17:14 #349771
Replied by tommylight on topic how to get better latency test results
Should be OK, but not the only important thing for EtherCAT, so in short: you can not know without actually testing it.
- Thank you received: 4153
22 Sep 2026 04:59 #349775
Replied by rodw on topic how to get better latency test results
Your PC sounds fine. Just make sure coalescing is turned off on your NIC. type man hm2_eth for some details on this.I turned off all the turbo mode, C-state,etc. But the latency test shows the jitter is 50-60us. Is it enough for Ethercat control? Is there anything else I need to do with.
