JMC Servo Drive Bricked!
10 Oct 2026 01:02 #350180 by concorde
JMC Servo Drive Bricked! was created by concorde
Hi Guys,
I'm new to the forum here. I have a milling machine with a JMC Servo motor (110JAS) driving the spindle. It has stopped working with an alarm AL-610 that started whilst I was loading/writing a new parameter to the servo drive via the JMC diagnostics software. As it was writing it triggered the alarm that caused the machine to e-stop. Powering back up even after leaving for 15minutes still produces the alarm. AL-610 is "encoder offline" fault. Despite that, I am confident the hardware is all fine and it is the parameters that have become corrupted. Does anyone know how to perform a factory reset?
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
12 Oct 2026 09:54 #350210 by Todd Zuercher
Replied by Todd Zuercher on topic JMC Servo Drive Bricked!
I don't know anything about that particular servo, but I would 1st suspect either a wiring issue (bad cable) or if the servo uses an absolute encoder, a dead backup battery for the encoder.
15 Oct 2026 04:30 #350266 by tommylight
Replied by tommylight on topic JMC Servo Drive Bricked!
Does the diagnostic software still communicate with the drive?
15 Oct 2026 17:17 #350288 by concorde
Replied by concorde on topic JMC Servo Drive Bricked!
I managed to fix the issue. The diagnostics software kept reporting the AF_610 and also AF_620 faults (encoder related faults), but the reason was it could not communicate with the encoder due to a bunch of random parameters set during the failed write/download from the diagnostics software.
However these parameters are locked out to users. However you can activate a "super user" level with code "jmc2018". This will allow you to alter the necessary P00 parameters.
Time to create page: 0.954 seconds
