- Thank you received: 8
Radius instead of tool diameter in milling tool table
- Wischi
- Topic Author
7 hours 46 minutes ago #350803
by Wischi
Radius instead of tool diameter in milling tool table was created by Wischi
Hello,
is it possible to use the radius instead of the tool diameter in a milling config tool table? I am using a tool presetter which only outputs the radius of a tool. Sadly it can't be changed.
Thanks.
Thanks.
- MaHa
- Thank you received: 193
7 hours 10 minutes ago - 7 hours 9 minutes ago #350804
by MaHa
Replied by MaHa on topic Radius instead of tool diameter in milling tool table
Last edit: 7 hours 9 minutes ago by MaHa.
The following user(s) said Thank You: Wischi
- Wischi
- Topic Author
6 hours 48 minutes ago #350807
by Wischi
Replied by Wischi on topic Radius instead of tool diameter in milling tool table
Thank you! But i was more thinking when having the tool table open (in gmoccapy) and entering the values. Because there, the column is in diameter. When you use the G10 command it actually multiplies the radius by 2 and enters that into the tool table.
But you’ve given me an idea: Write a gmoccapy macro which asks tool#, radius and length (all on label from presetter) and then run a G10 L1 P# R# Z# to update the table. This also prevents from entering values into the wrong column.
Time to create page: 0.044 seconds
