Can EMC2 open without a machine plugged in
03 May 2011 20:49 #9572
by K3Craig
Can EMC2 open without a machine plugged in was created by K3Craig
Hi all,
As you all know, there are noobs to this stuff all the time, now its my turn! I HAD a computer that had linux and emc on it, it was used soley for the cnc mill. Something decided it didn't want to work, and after a "snap" noise, the computer went dead. I'm in the process of building/rebuilding a computer for the mill, and plan to use EMC2. I downloaded the Live CD and am currently using that to try to open EMC2 on my laptop to familiarize myself with EMC2 because the "new" computer isn't done yet. EMC tries to open, i set the configuration to the mill we have, and EMC fails to open, and I'm assuming, because the machine is not hooked up to the laptop. Is there a way I can run EMC2 without the machine hooked up, so that i might be a little more familiar with the program before the actual computer is ready?? Any help would be great!! Thanks in advance!
03 May 2011 22:52 #9576
by BigJohnT
Replied by BigJohnT on topic Re:Can EMC2 open without a machine plugged in
If your config just uses the parallel port you can open Axis with no problem. If your machine uses a PCI card then just open up the Axis Sim and use that to feel your way around.
03 May 2011 23:29 #9578
by K3Craig
Replied by K3Craig on topic Re:Can EMC2 open without a machine plugged in
Thanks John,
I have tried to open several configs, and i just get the same thing. I'm having trouble finding out what it is i'm doing wrong. I hate to post something so large, but this is what comes up after i try to open any config; (I appreciate the patients you all have dealing with the new guys!)
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/ubuntu/emc2/configs/sim-1'
Machine configuration file is 'axis.ini'
INIFILE=/home/ubuntu/emc2/configs/sim-1/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
waiting for s.axes
waiting for s.axes
(theres a million 6 of these waiting for s.axes thingys)
waiting for s.axes
waiting for s.axes
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=7707
Killing task milltask, PID=7795
Timeout, trying kill -9
Cleanup done
Debug file information:
Invalid configuration of axes is preventing EMC from starting
7707
PID TTY STAT TIME COMMAND
7795
7795 ? R 0:05 milltask -ini /home/ubuntu/emc2/configs/sim-1/axis.ini
7795 ? R 0:06 milltask -ini /home/ubuntu/emc2/configs/sim-1/axis.ini
7795 ? R 0:07 milltask -ini /home/ubuntu/emc2/configs/sim-1/axis.ini
/usr/bin/emc: line 358: 7795 Killed $EMCTASK -ini "$INIFILE"
Stopping realtime threads
Unloading hal components
Kernel message information:
[11228.075500] I-pipe: Domain RTAI registered.
[11228.075509] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[11228.075512] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[11228.075562] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[11228.075564] PIPELINE layers:
[11228.075568] fcc21e20 9ac15d93 RTAI 200
[11228.075571] c085cb20 0 Linux 100
[11228.099458] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[11228.099738] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[11228.099746] RTAI[sched]: hard timer type/freq = APIC/12499738(Hz); default timing: periodic; linear timed lists.
[11228.099751] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999876000 hz.
[11228.099754] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[11228.099845] RTAI[usi]: enabled.
[11228.151957] RTAI[math]: loaded.
[11237.602376] RTAI[math]: unloaded.
[11237.643785] SCHED releases registered named ALIEN RTGLBH
[11237.672756] RTAI[malloc]: unloaded.
[11237.773001] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[11237.777698] I-pipe: Domain RTAI unregistered.
[11237.777789] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.3
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
Cleanup done
7707
7795
03 May 2011 23:58 #9579
by BigJohnT
The waiting for s.axes flood is usually from upgrading from 2.3 to 2.4 and trying to run a 2.3 config. How did you install EMC?
Some reading on upgrading here
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UpdatingTo2.4
Oh, I was a newbee too once![:) :)](/media/kunena/emoticons/smile.png)
04 May 2011 01:16 #9580
by K3Craig
Thanks so much John,
I checked that i was at a 2.4 version and it was, but just for grins, i tried to update it anyway and ran out of room before it could finish. I'm sure its because its running off the Live CD I made today from the website, and sure there just wasn't enough RAM left to do it all. I tried it again anyway after it updated what it could, and still had the same problem. Could it be simply the fact that its trying to run from the CD and not from an installed version of UBUNTU?
Thanks again!
Thanks again!
04 May 2011 11:50 #9583
by BigJohnT
I'm confused as to what is getting updated if your running from the LiveCD? Can you give a bit more detail about what your doing?
04 May 2011 17:55 #9602
by K3Craig
I have been running Ubuntu right from the CD, what it is updating for sure I don't know. From that link that you providied, I followed its instructions, and ran out of memory to complete the update. I'm fairly sure the reason it can't complete it is because I am running it right off the CD, and there for, it's not writing anything to the hard drive, but to the RAM. There simply isn't enough room in the RAM to complete everything. I went to the package manager and unmarked as many things as i could that did not pertain to EMC, wondering if even an update to that particular package might trigger a response from the program. That update went through, but i still got the same results. My best guess is, because I was running Ubantu straight from the CD, the latency from CD to RAM to processor is probably why the program wouldn't open, that, and I was doing that on the laptop, which with its power saver stuff, creates its own latency problems, but I've been wrong before. I'm in search today for an inexpensive computer to dedicate to the CNC and I will install Ubuntu and EMC2 right to the hard drive... Hope this makes sense?
Craig
Craig
04 May 2011 18:28 #9603
by BigJohnT
Yep, you have to install it...
05 May 2011 02:35 #9605
by K3Craig
Well John.....
I have a new one for you.....here's my error....
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.3
Machine configuration directory is '/home/fponk/emc2/configs/Sherline3Axis'
Machine configuration file is 'Sherline3Axis_inch.ini'
INIFILE=/home/fponk/emc2/configs/Sherline3Axis/Sherline3Axis_inch.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Realtime system did not load
Killing task emcsvr, PID=1596
Cleanup done
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1596
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e8000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
[ 0.000000] BIOS-e820: 000000000fff0000 - 000000000ffffc00 (ACPI data)
[ 0.000000] BIOS-e820: 000000000ffffc00 - 0000000010000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fffe0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xfff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CEFFF write-protect
[ 0.000000] CF000-DBFFF uncachable
[ 0.000000] DC000-DFFFF write-back
[ 0.000000] E0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000100000 mask FF0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000000000 - 0000000000100000 (usable) ==> (reserved)
[ 0.000000] WARNING: BIOS bug: CPU MTRRs don't cover all of memory, losing 0MB of RAM.
[ 0.000000]
[ cut here ]
[ 0.000000] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/arch/x86/kernel/cpu/mtrr/cleanup.c:1092 mtrr_trim_uncached_memory+0x306/0x328()
[ 0.000000] Hardware name: Compaq PC
[ 0.000000] Modules linked in:
[ 0.000000] Pid: 0, comm: swapper Not tainted 2.6.32-122-rtai #rtai
[ 0.000000] Call Trace:
[ 0.000000] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 0.000000] [<c075a1a1>] ? mtrr_trim_uncached_memory+0x306/0x328
[ 0.000000] [<c014315a>] warn_slowpath_null+0x1a/0x20
[ 0.000000] [<c075a1a1>] mtrr_trim_uncached_memory+0x306/0x328
[ 0.000000] [<c0755050>] setup_arch+0x414/0x67c
[ 0.000000] [<c05674a9>] ? printk+0xab/0x112
[ 0.000000] [<c0751655>] start_kernel+0xbe/0x399
[ 0.000000] [<c07510aa>] i386_start_kernel+0xaa/0xb1
[ 0.000000] ---[ end trace a7919e7f17c0a725 ]---
[ 0.000000] update e820 for mtrr
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e8000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000000fff0000 (usable)
[ 0.000000] modified: 000000000fff0000 - 000000000ffffc00 (ACPI data)
[ 0.000000] modified: 000000000ffffc00 - 0000000010000000 (ACPI NVS)
[ 0.000000] modified: 00000000fffe0000 - 0000000100000000 (reserved)
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000000fff0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 000fc00000 page 2M
[ 0.000000] 000fc00000 - 000fff0000 page 4k
[ 0.000000] kernel direct mapping tables up to fff0000 @ 8b5000-8ba000
[ 0.000000] RAMDISK: 0b3b3000 - 0c03324b
[ 0.000000] ACPI: RSDP 000f7ab0 00014 (v00 PTLTD )
[ 0.000000] ACPI: RSDT 0fffdd4d 0002C (v01 PTLTD RSDT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 0ffffb65 00074 (v01 COMPAQ ASPEN 06040000 PTL_ 000F4240)
[ 0.000000] ACPI: DSDT 0fffdd79 01DEC (v01 Compaq Aspen 06040000 MSFT 0100000B)
[ 0.000000] ACPI: FACS 0fffffc0 00040
[ 0.000000] ACPI: BOOT 0ffffbd9 00027 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 255MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 0fff0000
[ 0.000000] low ram: 0 - 0fff0000
[ 0.000000] node 0 low ram: 00000000 - 0fff0000
[ 0.000000] node 0 bootmap 008b6000 - 008b8000
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 000fff0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [000b3b3000 - 000c03324b] RAMDISK ==> [000b3b3000 - 000c03324b]
[ 0.000000] #5 [000009f800 - 0000100000] BIOS reserved ==> [000009f800 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4108] BRK ==> [00008b1000 - 00008b4108]
[ 0.000000] #7 [00008b5000 - 00008b6000] PGTABLE ==> [00008b5000 - 00008b6000]
[ 0.000000] #8 [00008b6000 - 00008b8000] BOOTMAP ==> [00008b6000 - 00008b8000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000100 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0000fff0
[ 0.000000] HighMem 0x0000fff0 -> 0x0000fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0x00000100 -> 0x0000fff0
[ 0.000000] On node 0 totalpages: 65264
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1003000
[ 0.000000] DMA zone: 30 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3810 pages, LIFO batch:0
[ 0.000000] Normal zone: 480 pages used for memmap
[ 0.000000] Normal zone: 60944 pages, LIFO batch:15
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x8008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] No local APIC present or hardware disabled
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 10000000 (gap: 10000000:effe0000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64754
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=6005ef92-f227-4f30-a348-1d2972047048 ro quiet splash
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 1305280 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 236456k/262080k available (4539k kernel code, 24340k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xd07f0000 - 0xff7fe000 ( 752 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xcfff0000 ( 255 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 548.897 MHz processor.
[ 0.004017] Calibrating delay loop (skipped), value calculated using timer frequency.. 1097.79 BogoMIPS (lpj=2195588)
[ 0.004111] Security Framework initialized
[ 0.004231] AppArmor: AppArmor initialized
[ 0.004271] Mount-cache hash table entries: 512
[ 0.004778] Initializing cgroup subsys ns
[ 0.004800] Initializing cgroup subsys cpuacct
[ 0.004819] Initializing cgroup subsys memory
[ 0.004858] Initializing cgroup subsys devices
[ 0.004870] Initializing cgroup subsys freezer
[ 0.004880] Initializing cgroup subsys net_cls
[ 0.004954] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.004968] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.004983] mce: CPU supports 4 MCE banks
[ 0.005057] Performance Events: AMD PMU driver.
[ 0.005124] ... version: 0
[ 0.005133] ... bit width: 48
[ 0.005140] ... generic registers: 4
[ 0.005149] ... value mask: 0000ffffffffffff
[ 0.005159] ... max period: 00007fffffffffff
[ 0.005168] ... fixed-purpose events: 0
[ 0.005176] ... event mask: 000000000000000f
[ 0.005191] Checking 'hlt' instruction... OK.
[ 0.020220] SMP alternatives: switching to UP code
[ 0.043316] Freeing SMP alternatives: 31k freed
[ 0.043404] ACPI: Core revision 20090903
[ 0.053180] ACPI: setting ELCR to 0200 (from 0e00)
[ 0.053724] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.053758] ftrace: allocating 21003 entries in 42 pages
[ 0.074199] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.074217] weird, boot CPU (#0) not listed by the BIOS.
[ 0.074225] SMP motherboard not detected.
[ 0.074236] Local APIC not detected. Using dummy APIC emulation.
[ 0.074244] SMP disabled
[ 0.075107] Brought up 1 CPUs
[ 0.075121] Total of 1 processors activated (1097.79 BogoMIPS).
[ 0.076103] CPU0 attaching NULL sched-domain.
[ 0.076779] devtmpfs: initialized
[ 0.078193] regulator: core version 0.5
[ 0.078448] NET: Registered protocol family 16
[ 0.078973] EISA bus registered
[ 0.079019] ACPI: bus type pci registered
[ 0.095529] PCI: PCI BIOS revision 2.10 entry at 0xfd7ee, last bus=1
[ 0.095541] PCI: Using configuration type 1 for base access
[ 0.099046] bio: create slab <bio-0> at 0
[ 0.100334] ACPI: EC: Look up EC in DSDT
[ 0.109358] ACPI: Interpreter enabled
[ 0.109374] ACPI: (supports S0 S5)
[ 0.109418] ACPI: Using PIC for interrupt routing
[ 0.122383] ACPI: No dock devices found.
[ 0.122951] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.123132] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe8000000-0xefffffff]
[ 0.123153] pci 0000:00:00.0: reg 14 32bit mmio pref: [0xe0015000-0xe0015fff]
[ 0.123172] pci 0000:00:00.0: reg 18 io port: [0x1490-0x1493]
[ 0.123338] pci 0000:00:03.0: reg 10 io port: [0x1400-0x143f]
[ 0.123402] pci 0000:00:03.0: supports D2
[ 0.123444] pci 0000:00:04.0: reg 10 io port: [0x1000-0x10ff]
[ 0.123461] pci 0000:00:04.0: reg 14 32bit mmio: [0xe0014800-0xe00148ff]
[ 0.123499] pci 0000:00:04.0: reg 30 32bit mmio pref: [0x000000-0x03ffff]
[ 0.123636] pci 0000:00:07.1: reg 20 io port: [0x1480-0x148f]
[ 0.123717] pci 0000:00:07.2: reg 20 io port: [0x1440-0x145f]
[ 0.123793] pci 0000:00:07.3: reg 20 io port: [0x1460-0x147f]
[ 0.123900] pci 0000:00:07.4: quirk: region 8000-80ff claimed by vt82c586 ACPI
[ 0.123918] pci 0000:00:07.4: quirk: region 4000-400f claimed by vt82c686 SMB
[ 0.123981] pci 0000:00:09.0: reg 10 32bit mmio: [0xe0000000-0xe000ffff]
[ 0.124031] pci 0000:00:09.0: reg 14 io port: [0x1498-0x149f]
[ 0.124090] pci 0000:00:09.0: PME# supported from D3hot D3cold
[ 0.124104] pci 0000:00:09.0: PME# disabled
[ 0.124164] pci 0000:00:0c.0: reg 10 32bit mmio: [0xe0014000-0xe00147ff]
[ 0.124182] pci 0000:00:0c.0: reg 14 32bit mmio: [0xe0010000-0xe0013fff]
[ 0.124241] pci 0000:00:0c.0: supports D2
[ 0.124251] pci 0000:00:0c.0: PME# supported from D2 D3hot
[ 0.124263] pci 0000:00:0c.0: PME# disabled
[ 0.124371] pci 0000:01:05.0: reg 10 32bit mmio: [0xe1000000-0xe1ffffff]
[ 0.124388] pci 0000:01:05.0: reg 14 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.124405] pci 0000:01:05.0: reg 18 32bit mmio pref: [0xf8000000-0xf807ffff]
[ 0.124436] pci 0000:01:05.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.124524] pci 0000:00:01.0: bridge 32bit mmio: [0xe1000000-0xe1ffffff]
[ 0.124539] pci 0000:00:01.0: bridge 32bit mmio pref: [0xf0000000-0xf80fffff]
[ 0.124559] pci_bus 0000:00: on NUMA node 0
[ 0.124586] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.125225] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PPB_._PRT]
[ 0.132473] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 7 *10 11 12)
[ 0.132954] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7 *10 11 12)
[ 0.133324] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 7 10 11 12) *0, disabled.
[ 0.133800] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 10 *11 12)
[ 0.134232] vgaarb: device added: PCI:0000:01:05.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.134247] vgaarb: loaded
[ 0.134812] SCSI subsystem initialized
[ 0.135101] libata version 3.00 loaded.
[ 0.135481] usbcore: registered new interface driver usbfs
[ 0.135533] usbcore: registered new interface driver hub
[ 0.135674] usbcore: registered new device driver usb
[ 0.136348] ACPI: WMI: Mapper loaded
[ 0.136360] PCI: Using ACPI for IRQ routing
[ 0.136851] NetLabel: Initializing
[ 0.136863] NetLabel: domain hash size = 128
[ 0.136871] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.136939] NetLabel: unlabeled traffic allowed by default
[ 0.137094] Switching to clocksource tsc
[ 0.144738] AppArmor: AppArmor Filesystem Enabled
[ 0.144808] pnp: PnP ACPI init
[ 0.144878] ACPI: bus type pnp registered
[ 0.157279] pnp: PnP ACPI: found 12 devices
[ 0.157292] ACPI: ACPI bus type pnp unregistered
[ 0.157309] PnPBIOS: Disabled by ACPI PNP
[ 0.157358] system 00:00: iomem range 0xfffe0000-0xffffffff has been reserved
[ 0.157375] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.157390] system 00:00: iomem range 0x100000-0xfffffff could not be reserved
[ 0.157404] system 00:00: iomem range 0xe0000-0xfffff could not be reserved
[ 0.157439] system 00:06: ioport range 0x4d0-0x4d1 has been reserved
[ 0.157453] system 00:06: iomem range 0xfff09000-0xfff3ffff has been reserved
[ 0.157467] system 00:06: iomem range 0xfff49000-0xfff7ffff has been reserved
[ 0.192886] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.192899] pci 0000:00:01.0: IO window: disabled
[ 0.192916] pci 0000:00:01.0: MEM window: 0xe1000000-0xe1ffffff
[ 0.192931] pci 0000:00:01.0: PREFETCH window: 0xf0000000-0xf80fffff
[ 0.192974] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.192988] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.193001] pci_bus 0000:01: resource 1 mem: [0xe1000000-0xe1ffffff]
[ 0.193013] pci_bus 0000:01: resource 2 pref mem [0xf0000000-0xf80fffff]
[ 0.193168] NET: Registered protocol family 2
[ 0.193537] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.194628] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.195074] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.195429] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.195440] TCP reno registered
[ 0.195772] NET: Registered protocol family 1
[ 0.195857] pci 0000:00:07.0: Disabling VIA external APIC routing
[ 0.195944] pci 0000:01:05.0: Boot video device
[ 0.196238] Simple Boot Flag at 0x36 set to 0x1
[ 0.196752] Scanning for low memory corruption every 60 seconds
[ 0.197175] audit: initializing netlink socket (disabled)
[ 0.197224] type=2000 audit(1304545571.194:1): initialized
[ 0.229443] Trying to unpack rootfs image as initramfs...
[ 0.263484] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.279326] VFS: Disk quotas dquot_6.5.2
[ 0.279659] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.282288] fuse init (API version 7.13)
[ 0.282781] msgmni has been set to 462
[ 0.287500] alg: No test for stdrng (krng)
[ 0.287711] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.287727] io scheduler noop registered
[ 0.287736] io scheduler anticipatory registered
[ 0.287745] io scheduler deadline registered
[ 0.287961] io scheduler cfq registered (default)
[ 0.288374] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.288472] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.288769] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.288789] ACPI: Power Button [PWRB]
[ 0.289045] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.289060] ACPI: Power Button [PWRF]
[ 0.298894] isapnp: Scanning for PnP cards...
[ 0.308745] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.309003] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.310150] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.368112] brd: module loaded
[ 0.370281] loop: module loaded
[ 0.370857] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.373042] Fixed MDIO Bus: probed
[ 0.373197] PPP generic driver version 2.4.2
[ 0.373392] tun: Universal TUN/TAP device driver, 1.6
[ 0.373402] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.373797] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.373878] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.373932] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.380063] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.380082] PCI: setting IRQ 11 as level-triggered
[ 0.380101] uhci_hcd 0000:00:07.2: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.380135] uhci_hcd 0000:00:07.2: UHCI Host Controller
[ 0.380421] uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
[ 0.380493] uhci_hcd 0000:00:07.2: irq 11, io base 0x00001440
[ 0.380979] usb usb1: configuration #1 chosen from 1 choice
[ 0.381111] hub 1-0:1.0: USB hub found
[ 0.381161] hub 1-0:1.0: 2 ports detected
[ 0.381382] uhci_hcd 0000:00:07.3: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.381417] uhci_hcd 0000:00:07.3: UHCI Host Controller
[ 0.381615] uhci_hcd 0000:00:07.3: new USB bus registered, assigned bus number 2
[ 0.381668] uhci_hcd 0000:00:07.3: irq 11, io base 0x00001460
[ 0.382106] usb usb2: configuration #1 chosen from 1 choice
[ 0.382222] hub 2-0:1.0: USB hub found
[ 0.382269] hub 2-0:1.0: 2 ports detected
[ 0.382667] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.388196] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.388244] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.388887] mice: PS/2 mouse device common for all mice
[ 0.389617] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.389675] rtc0: alarms up to one month, y3k, 242 bytes nvram
[ 0.390061] device-mapper: uevent: version 1.0.3
[ 0.390603] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.392670] device-mapper: multipath: version 1.1.0 loaded
[ 0.392687] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.395105] EISA: Probing bus 0 at eisa.0
[ 0.395130] Cannot allocate resource for EISA slot 1
[ 0.395158] Cannot allocate resource for EISA slot 4
[ 0.395191] Cannot allocate resource for EISA slot 8
[ 0.395201] EISA: Detected 0 cards.
[ 0.395212] cpuidle: using governor ladder
[ 0.395222] cpuidle: using governor menu
[ 0.396866] TCP cubic registered
[ 0.397529] NET: Registered protocol family 10
[ 0.399390] lo: Disabled Privacy Extensions
[ 0.400587] NET: Registered protocol family 17
[ 0.403849] Using IPI No-Shortcut mode
[ 0.404256] registered taskstats version 1
[ 0.404842] rtc_cmos 00:03: setting system clock to 2011-05-04 21:46:12 UTC (1304545572)
[ 0.404859] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.404867] EDD information not available.
[ 0.409799] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.995111] isapnp: No Plug & Play device found
[ 2.079390] Freeing initrd memory: 12800k freed
[ 2.131092] Freeing unused kernel memory: 620k freed
[ 2.133888] Write protecting the kernel text: 4540k
[ 2.133993] Write protecting the kernel read-only data: 1668k
[ 2.241341] udev: starting version 151
[ 3.011565] Linux agpgart interface v0.103
[ 3.053745] Linux Tulip driver version 1.1.15 (Feb 27, 2007)
[ 3.054759] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
[ 3.054775] PCI: setting IRQ 10 as level-triggered
[ 3.054795] tulip 0000:00:04.0: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
[ 3.055291] tulip0: MII transceiver #1 config 3000 status 7809 advertising 01e1.
[ 3.062804] eth0: Lite-On 82c168 PNIC rev 32 at Port 0x1000, 00:a0:cc:d2:5d:33, IRQ 10.
[ 3.112150] pata_via 0000:00:07.1: version 0.3.4
[ 3.112816] scsi0 : pata_via
[ 3.113835] scsi1 : pata_via
[ 3.114412] ata1: PATA max UDMA/66 cmd 0x1f0 ctl 0x3f6 bmdma 0x1480 irq 14
[ 3.114428] ata2: PATA max UDMA/66 cmd 0x170 ctl 0x376 bmdma 0x1488 irq 15
[ 3.142427] Floppy drive(s): fd0 is 1.44M
[ 3.144678] agpgart-amdk7 0000:00:00.0: AMD Irongate chipset
[ 3.144718] agpgart-amdk7 0000:00:00.0: AMD 751 chipset with NVidia GeForce; forcing 1X due to errata
[ 3.161213] FDC 0 is a post-1991 82077
[ 3.184508] agpgart-amdk7 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 3.276743] ata1.00: ATA-4: QUANTUM FIREBALLlct10 30, A03.0900, max UDMA/66
[ 3.276760] ata1.00: 58633344 sectors, multi 16: LBA
[ 3.276854] ata1.00: limited to UDMA/33 due to 40-wire cable
[ 3.292735] ata1.00: configured for UDMA/33
[ 3.293274] scsi 0:0:0:0: Direct-Access ATA QUANTUM FIREBALL A03. PQ: 0 ANSI: 5
[ 3.293936] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.295304] sd 0:0:0:0: [sda] 58633344 512-byte logical blocks: (30.0 GB/27.9 GiB)
[ 3.295575] sd 0:0:0:0: [sda] Write Protect is off
[ 3.295592] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.295731] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.296652] sda: sda1 sda2 < sda5 >
[ 3.334239] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.512439] ata2.00: ATAPI: COMPAQ DVD-ROM SD-608, BC02, max MWDMA2, CDB intr
[ 3.528430] ata2.00: configured for MWDMA2
[ 3.530088] scsi 1:0:0:0: CD-ROM COMPAQ DVD-ROM SD-608 BC02 PQ: 0 ANSI: 5
[ 3.535776] sr0: scsi3-mmc drive: 4x/32x cd/rw xa/form2 cdda tray
[ 3.535794] Uniform CD-ROM driver Revision: 3.20
[ 3.537086] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 3.537834] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 3.647352] ohci1394 0000:00:0c.0: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
[ 3.664155] [drm] Initialized drm 1.1.0 20060810
[ 3.706025] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[10] MMIO=[e0014000-e00147ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 3.858578] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
[ 3.858605] nouveau 0000:01:05.0: PCI INT A -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 3.874162] [drm] nouveau 0000:01:05.0: Detected an NV10 generation card (0x017100a3)
[ 3.874437] [drm] nouveau 0000:01:05.0: Attempting to load BIOS image from PROM
[ 4.049233] [drm] nouveau 0000:01:05.0: ... appears to be valid
[ 4.050124] [drm] nouveau 0000:01:05.0: BMP BIOS found
[ 4.050137] [drm] nouveau 0000:01:05.0: BMP version 5.20
[ 4.050150] [drm] nouveau 0000:01:05.0: Bios version 04.17.00.24
[ 4.050164] [drm] nouveau 0000:01:05.0: Found Display Configuration Block version 2.0
[ 4.050182] [drm] nouveau 0000:01:05.0: Raw DCB entry 0: 01000100 000088b8
[ 4.050198] [drm] nouveau 0000:01:05.0: Raw DCB entry 1: 01020312 00000000
[ 4.050210] [drm] nouveau 0000:01:05.0: Raw DCB entry 2: 02010311 00000003
[ 4.050914] [drm] nouveau 0000:01:05.0: Loading NV17 power sequencing microcode
[ 4.050931] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 0 at offset 0xC70A
[ 4.051006] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 1 at offset 0xC9C3
[ 4.051062] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 2 at offset 0xC801
[ 4.051125] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 3 at offset 0xCEC6
[ 4.051145] [drm] nouveau 0000:01:05.0: Parsing VBIOS init table 4 at offset 0xC95E
[ 4.073561] [TTM] Zone kernel: Available graphics memory: 125086 kiB.
[ 4.073619] [drm] nouveau 0000:01:05.0: 64 MiB VRAM
[ 4.073787] agpgart-amdk7 0000:00:00.0: AGP 1.0 bridge
[ 4.073835] agpgart-amdk7 0000:00:00.0: putting AGP V2 device into 1x mode
[ 4.073902] nouveau 0000:01:05.0: putting AGP V2 device into 1x mode
[ 4.073918] [drm] nouveau 0000:01:05.0: 128 MiB GART (aperture)
[ 4.074822] [drm] nouveau 0000:01:05.0: Allocating FIFO number 0
[ 4.081795] [TTM] AGP Bind memory failed.
[ 4.081818] [TTM] Couldn't bind backend.
[ 4.082184] [drm] nouveau 0000:01:05.0: error allocating DMA push buffer: -22
[ 4.082195] [drm] nouveau 0000:01:05.0: pushbuf -12
[ 4.082206] [drm] nouveau 0000:01:05.0: nouveau_channel_free: freeing fifo 0
[ 4.082219]
[ cut here ]
[ 4.082249] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.082261] Hardware name: Compaq PC
[ 4.082269] Bad IO access at port 0x48 (return inl(port))
[ 4.082277] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.082333] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.082345] Call Trace:
[ 4.082375] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.082392] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.082406] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.082422] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.082436] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.082451] [<c0349f22>] ioread32+0x22/0x40
[ 4.082574] [<d09db243>] nouveau_fence_update+0xa3/0xb0 [nouveau]
[ 4.082624] [<d09d2420>] nouveau_channel_free+0x60/0x1f0 [nouveau]
[ 4.082674] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.082693] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.082743] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.082829] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.082876] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.082924] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.082971] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.083013] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.083037] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.083098] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.083125] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.083141] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.083167] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.083187] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.083204] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.083220] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.083235] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.083251] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.083267] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.083282] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.083299] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.083315] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.083336] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.083353] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.083392] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.083443] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.083458] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.083506] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.083534] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.083551] [<c010340d>] syscall_call+0x7/0xb
[ 4.083563] ---[ end trace a7919e7f17c0a727 ]---
[ 4.083947]
[ cut here ]
[ 4.083974] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.083985] Hardware name: Compaq PC
[ 4.083993] Bad IO access at port 0x0 (return inl(port))
[ 4.084000] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.084162] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.084173] Call Trace:
[ 4.084193] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.084209] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.084223] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.084237] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.084251] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.084266] [<c0349f22>] ioread32+0x22/0x40
[ 4.084395] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.084559] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.084614] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.084630] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.084676] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.084724] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.084741] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.084787] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.084844] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.084892] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.084939] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.084987] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.085027] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.085048] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.085109] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.085129] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.085144] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.085163] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.085179] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.085195] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.085210] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.085225] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.085241] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.085256] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.085271] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.085288] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.085304] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.085319] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.085335] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.085373] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.085423] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.085439] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.085488] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.085508] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.085524] [<c010340d>] syscall_call+0x7/0xb
[ 4.085535] ---[ end trace a7919e7f17c0a728 ]---
[ 4.085545]
[ cut here ]
[ 4.085561] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.085572] Hardware name: Compaq PC
[ 4.085580] Bad IO access at port 0x0 (return inl(port))
[ 4.085587] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.085633] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.085642] Call Trace:
[ 4.085657] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.085671] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.085685] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.085700] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.085714] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.085728] [<c0349f22>] ioread32+0x22/0x40
[ 4.085778] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.085831] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.085884] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.085898] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.085944] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.085992] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.086008] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.086053] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.086098] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.086145] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.086192] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.086240] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.086279] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.086297] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.086357] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.086374] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.086389] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.086406] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.086421] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.086437] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.086453] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.086468] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.086484] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.086498] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.086513] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.086530] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.086545] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.086560] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.086577] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.086614] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.086664] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.086678] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.086727] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.086746] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.086761] [<c010340d>] syscall_call+0x7/0xb
[ 4.086772] ---[ end trace a7919e7f17c0a729 ]---
[ 4.086780]
[ cut here ]
[ 4.086795] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.086805] Hardware name: Compaq PC
[ 4.086813] Bad IO access at port 0x0 (return inl(port))
[ 4.086820] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.086864] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.086873] Call Trace:
[ 4.086886] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.086901] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.086915] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.086929] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.086944] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.086958] [<c0349f22>] ioread32+0x22/0x40
[ 4.087008] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.087060] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.087112] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.087127] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.087172] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.087221] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.087236] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.087281] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.087325] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.087372] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.087418] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.087465] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.087504] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.087522] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.087581] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.087597] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.087613] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.087629] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.087645] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.087661] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.087676] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.087691] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.087707] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.087722] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.087736] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.087753] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.087768] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.087783] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.087799] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.087834] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.087884] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.087898] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.087947] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.087966] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.087981] [<c010340d>] syscall_call+0x7/0xb
[ 4.087991] ---[ end trace a7919e7f17c0a72a ]---
[ 4.087999]
[ cut here ]
[ 4.088018] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.088070] Hardware name: Compaq PC
[ 4.088079] Bad IO access at port 0x0 (return inl(port))
[ 4.088087] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.088132] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.088141] Call Trace:
[ 4.088156] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.088171] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.088184] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.088199] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.088213] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.088228] [<c0349f22>] ioread32+0x22/0x40
[ 4.088279] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.088332] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.088384] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.088399] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.088445] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.088494] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.088510] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.088555] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.088598] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.088645] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.088692] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.088739] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.088778] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.088796] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.088856] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.088873] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.088888] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.088905] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.088921] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.088937] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.088952] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.088968] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.088983] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.088998] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.089013] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.089030] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.089045] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.089061] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.089077] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.089112] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.089162] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.089177] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.089226] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.089244] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.089259] [<c010340d>] syscall_call+0x7/0xb
[ 4.089269] ---[ end trace a7919e7f17c0a72b ]---
[ 4.089278]
[ cut here ]
[ 4.089293] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.089304] Hardware name: Compaq PC
[ 4.089312] Bad IO access at port 0x0 (return inl(port))
[ 4.089319] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.089362] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.089371] Call Trace:
[ 4.089385] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.089400] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.089413] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.089428] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.089442] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.089456] [<c0349f22>] ioread32+0x22/0x40
[ 4.089506] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.089558] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.089610] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.089625] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.089670] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.089719] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.089735] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.089780] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.089821] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.089868] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.089914] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.089962] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.090001] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.090019] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.090079] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.090097] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.090113] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.090130] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.090145] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.090161] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.090177] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.090192] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.090208] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.090223] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.090238] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.090255] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.090270] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.090285] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.090302] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.090337] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.090387] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.090401] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.090451] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.090469] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.090484] [<c010340d>] syscall_call+0x7/0xb
[ 4.090494] ---[ end trace a7919e7f17c0a72c ]---
[ 4.090502]
[ cut here ]
[ 4.090516] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.090527] Hardware name: Compaq PC
[ 4.090535] Bad IO access at port 0x0 (return inl(port))
[ 4.090542] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.090585] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.090594] Call Trace:
[ 4.090608] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.090622] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.090636] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.090651] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.090665] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.090679] [<c0349f22>] ioread32+0x22/0x40
[ 4.090728] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.090781] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.090833] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.090848] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.090893] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.090941] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.090957] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.091002] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.091042] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.091089] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.091135] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.091183] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.091221] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.091239] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.091299] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.091317] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.091332] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.091349] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.091364] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.091381] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.091396] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.091411] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.091427] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.091442] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.091457] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.091473] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.091488] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.091503] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.091520] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.091554] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.091604] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.091619] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.091668] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.091686] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.091701] [<c010340d>] syscall_call+0x7/0xb
[ 4.091711] ---[ end trace a7919e7f17c0a72d ]---
[ 4.091719]
[ cut here ]
[ 4.091733] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.091744] Hardware name: Compaq PC
[ 4.091752] Bad IO access at port 0x0 (return inl(port))
[ 4.091759] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.091801] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.091810] Call Trace:
[ 4.091824] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.091839] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.091853] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.091867] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.091882] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.091896] [<c0349f22>] ioread32+0x22/0x40
[ 4.091944] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.091997] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.092089] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.092106] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.092152] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.092201] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.092217] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.092261] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.092302] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.092350] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.092397] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.092445] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.092483] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.092502] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.092561] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.092578] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.092593] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.092609] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.092624] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.092640] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.092655] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.092670] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.092686] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.092700] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.092715] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.092732] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.092747] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.092761] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.092777] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.092812] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.092861] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.092876] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.092924] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.092942] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.092957] [<c010340d>] syscall_call+0x7/0xb
[ 4.092967] ---[ end trace a7919e7f17c0a72e ]---
[ 4.092975]
[ cut here ]
[ 4.092989] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.092999] Hardware name: Compaq PC
[ 4.093007] Bad IO access at port 0x0 (return inl(port))
[ 4.093014] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.093057] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.093066] Call Trace:
[ 4.093080] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.093094] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.093108] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.093123] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.093137] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.093151] [<c0349f22>] ioread32+0x22/0x40
[ 4.093200] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.093252] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.093305] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.093319] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.093364] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.093413] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.093428] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.093473] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.093514] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.093561] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.093607] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.093655] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.093693] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.093712] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.093772] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.093788] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.093804] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.093820] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.093835] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.093852] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.093867] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.093882] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.093898] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.093912] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.093927] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.093944] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.093959] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.093974] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.093990] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.094026] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.094076] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.094090] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.094139] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.094157] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.094172] [<c010340d>] syscall_call+0x7/0xb
[ 4.094182] ---[ end trace a7919e7f17c0a72f ]---
[ 4.094189]
[ cut here ]
[ 4.094203] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/lib/iomap.c:43 bad_io_access+0x45/0x50()
[ 4.094214] Hardware name: Compaq PC
[ 4.094221] Bad IO access at port 0x0 (return inl(port))
[ 4.094228] Modules linked in: nouveau(+) ttm drm_kms_helper drm ohci1394 amd_k7_agp floppy i2c_algo_bit ieee1394 pata_via tulip agpgart
[ 4.094271] Pid: 140, comm: modprobe Tainted: G W 2.6.32-122-rtai #rtai
[ 4.094280] Call Trace:
[ 4.094293] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 4.094308] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.094322] [<c0349bb5>] ? bad_io_access+0x45/0x50
[ 4.094336] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 4.094350] [<c0349bb5>] bad_io_access+0x45/0x50
[ 4.094364] [<c0349f22>] ioread32+0x22/0x40
[ 4.094413] [<d09d96c8>] nouveau_dma_wait+0x38/0x1b0 [nouveau]
[ 4.094466] [<d09db4dc>] nouveau_fence_emit+0x12c/0x170 [nouveau]
[ 4.094518] [<d09db5a0>] nouveau_fence_new+0x80/0xe0 [nouveau]
[ 4.094532] [<c0349f22>] ? ioread32+0x22/0x40
[ 4.094577] [<d09d244b>] nouveau_channel_free+0x8b/0x1f0 [nouveau]
[ 4.094626] [<d09d2a8e>] nouveau_channel_alloc+0x39e/0x450 [nouveau]
[ 4.094641] [<c01142fa>] ? mtrr_add+0x4a/0x60
[ 4.094686] [<d09d17fb>] nouveau_card_init_channel+0x3b/0x170 [nouveau]
[ 4.094727] [<d08ffbb4>] ? drm_vblank_init+0x104/0x190 [drm]
[ 4.094774] [<d09d1bbc>] nouveau_card_init+0x28c/0x2c0 [nouveau]
[ 4.094820] [<d09d1c00>] ? nouveau_vga_set_decode+0x0/0x60 [nouveau]
[ 4.094868] [<d09d1e40>] nouveau_load+0x1e0/0x580 [nouveau]
[ 4.094907] [<d09015f5>] drm_get_dev+0x125/0x230 [drm]
[ 4.094925] [<c0252770>] ? sysfs_addrm_start+0x60/0xa0
[ 4.094984] [<d0a289f1>] nouveau_pci_probe+0x12/0x14 [nouveau]
[ 4.095000] [<c03571d3>] local_pci_probe+0x13/0x20
[ 4.095016] [<c0357428>] pci_device_probe+0x68/0x90
[ 4.095032] [<c03cf78d>] really_probe+0x4d/0x140
[ 4.095047] [<c01990ed>] ? __ipipe_restore_root+0x2d/0x40
[ 4.095063] [<c03cf89e>] driver_probe_device+0x1e/0x30
[ 4.095079] [<c03cf931>] __driver_attach+0x81/0x90
[ 4.095094] [<c03cedd3>] bus_for_each_dev+0x53/0x80
[ 4.095109] [<c03cf65e>] driver_attach+0x1e/0x20
[ 4.095124] [<c03cf8b0>] ? __driver_attach+0x0/0x90
[ 4.095139] [<c03cf055>] bus_add_driver+0xd5/0x280
[ 4.095156] [<c0357360>] ? pci_device_remove+0x0/0x40
[ 4.095171] [<c03cfc1a>] driver_register+0x6a/0x130
[ 4.095186] [<c01a48de>] ? ftrace_now+0x2e/0x50
[ 4.095202] [<c0357665>] __pci_register_driver+0x45/0xb0
[ 4.095237] [<d08fc263>] drm_init+0xf3/0x100 [drm]
[ 4.095287] [<d0a45045>] nouveau_init+0x45/0x47 [nouveau]
[ 4.095302] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 4.095350] [<d0a45000>] ? nouveau_init+0x0/0x47 [nouveau]
[ 4.095368] [<c0179781>] sys_init_module+0xb1/0x220
[ 4.095383] [<c010340d>] syscall_call+0x7/0xb
[ 4.095393] ---[ end trace a7919e7f17c0a730 ]---
[ 4.100974] [drm] nouveau 0000:01:05.0: Failed to idle channel 0.
[ 4.101411] [TTM] Zone kernel: Used memory at exit: 0 kiB.
[ 4.103831] nouveau 0000:01:05.0: PCI INT A disabled
[ 4.103870] nouveau: probe of 0000:01:05.0 failed with error -12
[ 4.116226] vga16fb: initializing
[ 4.116254] vga16fb: mapped to 0xc00a0000
[ 4.116790] fb0: VGA16 VGA frame buffer device
[ 4.331729] Console: switching to colour frame buffer device 80x30
[ 4.990181] ieee1394: Host added: ID:BUS[0-00:1023] GUID[0040ca122293e3f9]
[ 5.384252] xor: measuring software checksum speed
[ 5.404044] 8regs : 735.000 MB/sec
[ 5.424037] 8regs_prefetch: 698.000 MB/sec
[ 5.444038] 32regs : 367.000 MB/sec
[ 5.464041] 32regs_prefetch: 459.000 MB/sec
[ 5.484035] pII_mmx : 1502.000 MB/sec
[ 5.504035] p5_mmx : 1951.000 MB/sec
[ 5.504045] xor: using function: p5_mmx (1951.000 MB/sec)
[ 5.649700] device-mapper: dm-raid45: initialized v0.2594b
[ 5.970482] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 15.775897] Adding 731128k swap on /dev/sda5. Priority:-1 extents:1 across:731128k
[ 16.124984] udev: starting version 151
[ 17.812117] shpchp 0000:00:01.0: HPC vendor_id 1022 device_id 7007 ss_vid 0 ss_did 0
[ 17.812142] shpchp 0000:00:01.0: Cannot reserve MMIO region
[ 17.812267] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 18.075448] parport_pc: VIA 686A/8231 detected
[ 18.075466] parport_pc: probing current configuration
[ 18.075497] parport_pc: Current parallel port base: 0x378
[ 18.075605] parport0: PC-style at 0x378 (0x778), irq 7, using FIFO [PCSPP,TRISTATE,COMPAT,ECP]
[ 18.170629] parport_pc: VIA parallel port: io=0x378, irq=7
[ 18.182320] lp0: using parport0 (interrupt-driven).
[ 18.209217] via686a 0000:00:07.4: base address not set - upgrade BIOS or use force_addr=0xaddr
[ 18.265617] ppdev: user-space parallel port driver
[ 18.322908] psmouse serio1: ID: 10 00 64
[ 19.023634] input: ImPS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio1/input/input4
[ 19.416204] type=1505 audit(1304545591.511:2): operation="profile_load" pid=513 name="/sbin/dhclient3"
[ 19.417470] type=1505 audit(1304545591.511:3): operation="profile_load" pid=513 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 19.418184] type=1505 audit(1304545591.511:4): operation="profile_load" pid=513 name="/usr/lib/connman/scripts/dhclient-script"
[ 20.485724] ENS1371 0000:00:03.0: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 22.490858] type=1505 audit(1304545594.583:5): operation="profile_load" pid=637 name="/usr/share/gdm/guest-session/Xsession"
[ 22.500447] type=1505 audit(1304545594.595:6): operation="profile_replace" pid=640 name="/sbin/dhclient3"
[ 22.501743] type=1505 audit(1304545594.595:7): operation="profile_replace" pid=640 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 22.502509] type=1505 audit(1304545594.595:8): operation="profile_replace" pid=640 name="/usr/lib/connman/scripts/dhclient-script"
[ 22.793850] type=1505 audit(1304545594.887:9): operation="profile_load" pid=641 name="/usr/bin/evince"
[ 22.812271] type=1505 audit(1304545594.907:10): operation="profile_load" pid=641 name="/usr/bin/evince-previewer"
[ 22.844182] type=1505 audit(1304545594.939:11): operation="profile_load" pid=641 name="/usr/bin/evince-thumbnailer"
[ 33.104077] eth0: no IPv6 routers present
[ 70.912087] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[ 70.912108] ata1.00: BMDMA stat 0x25
[ 70.912125] ata1.00: failed command: READ DMA
[ 70.912155] ata1.00: cmd c8/00:e0:d8:71:44/00:00:00:00:00/e0 tag 0 dma 114688 in
[ 70.912161] res 51/84:00:b7:72:44/00:00:00:00:00/e0 Emask 0x1
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Shutting down and cleaning up EMC2...
Cleanup done
Debug file information:
1596
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000]
[ cut here ]
[ 4.082219]
[ cut here ]
[ 4.083947]
[ cut here ]
[ 4.085545]
[ cut here ]
[ 4.086780]
[ cut here ]
[ 4.087999]
[ cut here ]
[ 4.089278]
[ cut here ]
[ 4.090502]
[ cut here ]
[ 4.091719]
[ cut here ]
[ 4.092975]
[ cut here ]
[ 4.094189]
[ cut here ]
05 May 2011 20:55 #9614
by BigJohnT
Replied by BigJohnT on topic Re:Can EMC2 open without a machine plugged in
Can you tell me how you arrived at the error?
Time to create page: 0.138 seconds
