Mesa 5i20 - 7i37TA - 7i48
05 Apr 2012 17:35 #18997 by Will Gilmore
Mesa 5i20 - 7i37TA - 7i48 was created by Will Gilmore
I'm totally new to LinuxCNC. I'm working on a retrofit of a Tree Journeyman 320 vertical mill with Mesa boards and AMC drives.
I've done a bunch of wiring and I finally turned the computer on yesterday. I'm working on getting the relay outputs straightened out before I jump into getting the drives going. Here is my wiring diagram:
I generated my hal file with PnCConf. Wire 231 is connected to OUT7+ and wire 500 is connected to OUT7- on the 7i37. Here is part of the hal file.
# --- MACHINE-IS-ENABLED ---
setp hm2_5i20.0.gpio.047.is_output true
net machine-is-enabled hm2_5i20.0.gpio.047.out
I'm getting logic opposite to what I want. I open LinuxCNC. When OFF is displayed in lower left I can push the start button and the relay will energize. When ON is displayed I push start and nothing happens. I looked in HAL CONFIG and the machine-is-enabled signal is doing what I expect (TRUE when ON and FALSE when OFF).
Thanks.
05 Apr 2012 17:40 #18998 by PCW
Replied by PCW on topic Re:Mesa 5i20 - 7i37TA - 7i48
7I37TA inputs and outputs are inverted so for the outputs you would need for example:
setp hm2_5i20.0.gpio.047.invert_output true
for inputs you use the in_not pins
05 Apr 2012 19:05 #18999 by Will Gilmore
Replied by Will Gilmore on topic Re:Mesa 5i20 - 7i37TA - 7i48
I opened the hal file. Changed to this:
Now I can't get relay to energize in ON or OFF.
Also for inputs would I use something like this:
# --- HOME-X ---
net home-x <= hm2_5i20.0.gpio.025.in_not
Thanks.
05 Apr 2012 19:25 #19000 by BigJohnT
Replied by BigJohnT on topic Re:Mesa 5i20 - 7i37TA - 7i48
Unless your home-x signal is connected to axis.0.home-sw-in somewhere else in your hal file you will need that in your net line.
net home-x axis.N.home-sw-in <= hm2_5i20.0.gpio.025.in_not
05 Apr 2012 19:33 #19001 by Will Gilmore
ok i get the inputs. why isnt this working for me:
05 Apr 2012 19:52 #19002 by BigJohnT
Do you have something hooked to the machine-is-enabled signal somewhere else in your hal file to actually turn the output on?
05 Apr 2012 19:53 #19003 by BigJohnT
And have you read this basic hal info ?
06 Apr 2012 16:19 #19013 by PCW
"I opened the hal file. Changed to this:
net machine-is-enabled hm2_5i20.0.gpio.047.out"
Note that you need both:
in case that was not clear
06 Apr 2012 16:49 #19014 by Will Gilmore
Yes., but I need to read it several times and actually do it to understand it.
Ah ha!
08 Apr 2012 20:46 #19030 by cmorley
Replied by cmorley on topic Re:Mesa 5i20 - 7i37TA - 7i48
Obviously you figured out how to do this by hand but for others info:
In PNCconf there is a check button beside the signal pin type combo box, it is an invert checkbox.
Checking it will add the proper HAL code to invert the signal.
Time to create page: 0.455 seconds
