Mesa 5i20 - 7i37TA - 7i48
- Will Gilmore
I've done a bunch of wiring and I finally turned the computer on yesterday. I'm working on getting the relay outputs straightened out before I jump into getting the drives going. Here is my wiring diagram:
I generated my hal file with PnCConf. Wire 231 is connected to OUT7+ and wire 500 is connected to OUT7- on the 7i37. Here is part of the hal file.
# --- MACHINE-IS-ENABLED ---
setp hm2_5i20.0.gpio.047.is_output true
net machine-is-enabled hm2_5i20.0.gpio.047.out
I'm getting logic opposite to what I want. I open LinuxCNC. When OFF is displayed in lower left I can push the start button and the relay will energize. When ON is displayed I push start and nothing happens. I looked in HAL CONFIG and the machine-is-enabled signal is doing what I expect (TRUE when ON and FALSE when OFF).
Thanks.
- Thank you received: 5280
setp hm2_5i20.0.gpio.047.invert_output true
for inputs you use the in_not pins
- Will Gilmore
Now I can't get relay to energize in ON or OFF.
Also for inputs would I use something like this:
# --- HOME-X ---
net home-x <= hm2_5i20.0.gpio.025.in_not
Thanks.
- BigJohnT
- Thank you received: 1176
net home-x axis.N.home-sw-in <= hm2_5i20.0.gpio.025.in_not
- Will Gilmore
- BigJohnT
- BigJohnT
net machine-is-enabled hm2_5i20.0.gpio.047.out"
Note that you need both:
in case that was not clear
- Will Gilmore
Yes., but I need to read it several times and actually do it to understand it.And have you read this basic hal info ?
PCW wrote:
"I opened the hal file. Changed to this:
Ah ha!
- Thank you received: 2162
In PNCconf there is a check button beside the signal pin type combo box, it is an invert checkbox.
Checking it will add the proper HAL code to invert the signal.
