My scale is off by a factor of 5?
19 Apr 2012 16:43 #19377 by vladilinsky
My scale is off by a factor of 5? was created by vladilinsky
Hello,
I have just assembled my motors lead screw and sheaves
- motor 600 oz in nema 34 - ?200 steps per rev?
machmotion.com/cnc-products/drives-motor...n-stepper-motor.html
- motor sheave 72 notches
- lead screw sheave 32 notches
- lead screw 3/4-6 acme
I calculated this to be 0.0018" per step, PnCConf confirmed this under scale setup.
but when I try to test the setup it is nearly 1/5 of what it should be? ie if i tell it to go 10 inches it will go 2
Any Ideas?
Thanks for looking.
19 Apr 2012 18:07 #19378 by PCW
Replied by PCW on topic Re:My scale is off by a factor of 5?
what kind of step drive and what are its settings?
19 Apr 2012 18:21 #19379 by vladilinsky
Replied by vladilinsky on topic Re:My scale is off by a factor of 5?
Its a gecko 203v with no resistor (7Amp)
20 Apr 2012 00:22 #19381 by cmorley
Replied by cmorley on topic Re:My scale is off by a factor of 5?
doesn't gecko do micro stepping? if it does 5 time micro stepping then the scale would be wrong.
20 Apr 2012 00:51 #19382 by cmorley
hmm gecko 203 does 10 x microstepping.
you need to account for that.
Inches per step would be .0001875
but the scale is what is important.
What scale did pncconf give you ? 5333.3333
But one would expect it to be 1/10 of distance rather then 1/5th - I wonder if something else is happening too...
20 Apr 2012 01:21 #19384 by vladilinsky
It gives me a scale of 533.3333333
21 Apr 2012 05:06 #19412 by cmorley
then it seems you forgot to account for the micro stepping.
the gecko multiplies the 200 steps the motor has by 10.
22 Apr 2012 15:00 - 22 Apr 2012 15:00 #19435 by vladilinsky
after fixing the scale it looks to be much closer now, thanks!
Last edit: 22 Apr 2012 15:00 by vladilinsky.
Time to create page: 0.060 seconds
