7i64 & 7i70 - 7i44 - 5i23 support?
05 Jul 2012 02:53 #21596 by clkeck1
7i64 & 7i70 - 7i44 - 5i23 support? was created by clkeck1
Does pncconf support the 7i70 and 7i64 when connected to a 5i23?
Cory
05 Jul 2012 03:49 #21601 by cmorley
Replied by cmorley on topic Re:7i64 & 7i70 - 7i44 - 5i23 support?
It can. It needs the XML file for the 5i23's firmware which you probably don't have.
If you send me the firmware .PIN file I could hand build one for you.
What version of linuxcnc are you using ? I recommend the 2.5 from buidbot as it has the latest bugfixes.
05 Jul 2012 14:02 #21608 by clkeck1
Replied by clkeck1 on topic Re:7i64 & 7i70 - 7i44 - 5i23 support?
Here are links to the pin and bit file. I am running 2.5 now.
freeby.mesanet.com/svss8_8.pin
freeby.mesanet.com/svss8_8.bit
7i33 on P2
7i44 on P4
7i64 on port 0
7i64 on port 1
7i70 on port 2
Cory
06 Jul 2012 07:00 - 06 Jul 2012 07:02 #21641 by cmorley
Try this file. (unzip it of course)
You must put it in the /lib/firmware/hm2/5i23 folder
You need sudo rights to do that.
An easy way is to open a terminal and type sudo nautilus
it will ask your password then open a sudo file browser.
The 7i44 will be connected to the 5i23's P4 connector.
In PNCconf on I/O connector 4 you will see the sserial channels 0,1,2,3 and 4 (5-7 are not available in PNCconf presently)
select the cards on each channel and make sure the cards are connected to the same channels on the 7i44.
The 7i64 is nice as it has LED output so you can see if it works with out connected any field wires..
let me know of any problems.
Chris M
File Name: SSSV8_8.zip
File Size:1 KB
Last edit: 06 Jul 2012 07:02 by cmorley.
06 Jul 2012 23:45 #21656 by clkeck1
Chris
The 7i70 tab 0 lists inputs and tab 1 lists outputs.
Both of these should be inputs.
Cory
06 Jul 2012 23:56 #21657 by cmorley
hmm thats not what I got... I bet there are bug fixes that affect this - damn -
it seemd you need the buildbot version of 2.5 it has the current bug fixes.
Are you using the released version of linuxcnc?
06 Jul 2012 23:57 #21658 by cmorley
Did the 7i64 work out ?
07 Jul 2012 00:09 #21661 by clkeck1
7i64 looks right
The file should be SVSS though not SSSV. it is putting it backwards in the hal file on the firmware line.
Im running the released version of 2.5
Do i need to go to 2.6 pre?
Cory
07 Jul 2012 00:23 #21663 by cmorley
Sorry - Rename the XML file (you need sudo rights to do that.)
No you need 2.5 but the latest version - the released version is quite behind now.
2.6 pre has most of the fixes just not the very latest (2.5 is not always merged to 2.6 immediately)
So either use git and build from source or use buildbot to download the pre compiled version of 2.5
Unfortunately the buildbot is down right now.
Or just hand edit from this starting point :)
07 Jul 2012 04:17 #21667 by clkeck1
Are there other issues that the newest 2.5 will solve?
If its nothing major I will just hand edit the file.
Cory
Time to create page: 0.066 seconds
