7i73 Pendent Control
- johnjsb
21 Jul 2012 15:38 #22272
by johnjsb
7i73 Pendent Control was created by johnjsb
5i25>7i76>7i73
i have plugged in the 7i73 and can't find anything to configure. when i start linuxcnc the pendent blinks green 1hz so thats all correct.
i tried checking the on box for mpg on the first page and setting up increment to .1 but that throughs up errors when opening.
not sure if i'm doing it right. shouldn't a tab appear under smart serial it only shows 2 7i76 boards which i only have one.
- Thank you received: 5282
21 Jul 2012 16:40 - 21 Jul 2012 17:29 #22276
Replied by PCW on topic Re:7i73 Pendent Control
The 7I73 alas is not automatically configured
like most hardware, it needs the hal file setup to use it
If (in Axis) you do a show hal configuration you should see the
avalable 7I73 pins for the currently selected hardware and software modes
And it just dawned on me that maybe this thread is better suited to the pncconf
category if by "checking the box for mpg" you mean checking the _pncconf_ box for MPG
Last edit: 21 Jul 2012 17:29 by PCW. Reason: addition
- Thank you received: 2164
21 Jul 2012 18:30 #22289
Replied by cmorley on topic Re:7i73 Pendent Control
To use the 7i73 with PNCconf you need the very latest bug fixed version of linuxcnc.
Which has not been released yet.
Normally you can get it from buildbot, but the buildbot is down.
And even at that as of last night there is still one thing to fix in that HAl code so....
Your gonna have to do it by hand.
Get your config all good besides the MPG, because after hand editing if you change things in pncconf it will overwrite the editing.
- johnjsb
21 Jul 2012 19:23 #22293
by johnjsb
Replied by johnjsb on topic Re:7i73 Pendent Control
thats cool i'll just poke around inside axis see whats there.
i'm glad you told me my hal would be over written.
- johnjsb
21 Jul 2012 19:43 #22295
by johnjsb
ok figured out how to watch pins in hal.
oddly enough when rotated mpg pins 6-7 changed even though i was on 8-9.
i moved them all around and they still show up as 6-7.
at any rate how do i tie that to jog
do i manully edit hal, and if so were is it?
21 Jul 2012 20:05 - 21 Jul 2012 20:48 #22296
Just a hint here, for the MPG you do not use I/O pins but rather the 7I73s encoders....
Also pin numbers in HAL are logical pin numbers not physical pins
Last edit: 21 Jul 2012 20:48 by PCW. Reason: ommision
- johnjsb
21 Jul 2012 21:17 #22298
by johnjsb
oh ok is there a web page somewhere for physical pins to hal logic pins?
on the pendant it says enc0 is pin8 pin9.
did a watch in hal on everything that had enc on it got nothing.
the only logic pins that show anything in the hal is 6-7
21 Jul 2012 21:35 #22299
The 7I73 manual has the encoder/pin connections
For example, if you have a quadrature output MPG connected to 7I73 in8 and in9
(pins 14 and 15 on the 7I73s Input/output connector)
hm2_5i25.0.7i73.0.2.enc0 should count when the MPG is turned
21 Jul 2012 21:43 #22301
here is the pncconf way of doing it:
note that the pinname (hm2_5i25.0.7i73.0.2.enc0) might be different depending on where it is plugged into and what encoder you are using.
I'm also thiunking if you put this code in your custom_hal file then you could still use pncconf after to edit your config, because pncconf will not overwrite the custom_hal file.
At least this gives you the idea of how it can be done.
# ---spindle override signals to mesa encoder - mpg---
net so-count <= hm2_5i25.0.7i73.0.2.enc0
# connect spindle overide increments - MPG
setp halui.spindle-override.count-enable true
setp halui.spindle-override.direct-value false
setp halui.spindle-override.scale .01
net so-count => halui.spindle-override.counts
21 Jul 2012 21:44 #22302
Oh wait thats for spindle override... you wanted MPG jogging - hang on....
