7i77 Question
- Thank you received: 1467
05 Aug 2012 03:28 #22836
7i77 Question was created by Todd Zuercher
I am just starting to configure my first 7i77 setup. I have a simple question.
While I was trying to use PNCConf I did not notice where the drive enable switches (the 4 and 5th that go with the analog outs) are configured. Where and how are those assigned, or are they automatically set up when the pwms for the analog outs are configured?
- Thank you received: 2162
05 Aug 2012 03:49 #22838
Replied by cmorley on topic Re:7i77 Question
there are only two enables.
one for the 0-4 analogs
and one for the 5th
the 5th is set up that way so you could enable a spindle separately.
if you look in the x axis section :
# enable _all_ sserial pwmgens
net x-enable hm2_5i25.0.7i77.0.1.analogena
if you select an analog spindle use analog 5
and one for the 5th
Time to create page: 0.054 seconds
