HelloI also have the combination 5i20 + 7i52s + 2x 7i37TA. This runs so far. But as soon as I add an encoder (x, y, or z axis), LinuxCNC stops with an error message. I have set all the jumpers on the card to TTL.
LinuxCNC gives the following error message:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.3
Machine configuration directory is '/home/cnc/linuxcnc/configs/LinuxCNC-5i20-Axis'
Machine configuration file is 'LinuxCNC-5i20-Axis.ini'
INIFILE=/home/cnc/linuxcnc/configs/LinuxCNC-5i20-Axis/LinuxCNC-5i20-Axis.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./LinuxCNC-5i20-Axis.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i20 at 0000:04:01.0
hm2/hm2_5i20.0: Low Level init 0.15
hm2/hm2_5i20.0: 72 I/O Pins used:
hm2/hm2_5i20.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i20.0: IO Pin 011 (P2-23): StepGen #5, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 012 (P2-25): StepGen #5, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 013 (P2-27): StepGen #4, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 014 (P2-29): StepGen #4, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 015 (P2-31): StepGen #3, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 016 (P2-33): StepGen #3, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 017 (P2-35): StepGen #2, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 018 (P2-37): StepGen #2, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 019 (P2-39): StepGen #1, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 020 (P2-41): StepGen #1, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 021 (P2-43): StepGen #0, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 022 (P2-45): StepGen #0, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPorShutting down and cleaning up LinuxCNC...
Running HAL shutdown script
t
hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
hm2/hm2_5i20.0: registered
hm2_5i20.0: initialized AnyIO board at 0000:04:01.0
hm2_5i20.0: dropping AnyIO board at 0000:04:01.0
hm2/hm2_5i20.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./LinuxCNC-5i20-Axis.hal:103: Signal 'x-pos-fb' can not add OUT pin 'hm2_5i20.0.encoder.01.position', it already has OUT pin 'hm2_5i20.0.stepgen.00.position-fb'
827
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f09527e0000
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Do Sep 15 11:31:57 CEST 2022
UTC Date: Do Sep 15 09:31:57 UTC 2022
this program: /usr/bin/linuxcnc_info
uptime: 11:31:57 up 3 min, 1 user, load average: 0.35, 0.20, 0.08
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/cnc/linuxcnc/configs/LinuxCNC-5i20-Axis
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE: de_CH:de
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1920x1200 pixels (508x317 millimeters)
PATH: /usr/bin:/home/cnc/linuxcnc/configs/LinuxCNC-5i20-Axis/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: LinuxCNC
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.249-2 (2022-06-30)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-21-rt-amd64 root=UUID=87a5b284-9e7c-48e1-8a7e-d5c34ffe854b ro quiet
model name: Intel(R) Pentium(R) Dual CPU E2140 @ 1.60GHz
cores: 2
cpu MHz: 1224.818
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.3
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
| Status=Nicht/Installiert/Config/U=Entpackt/halb konFiguriert/
Halb installiert/Trigger erWartet/Trigger anhängig
|/ Fehler?=(kein)/R=Neuinstallation notwendig (Status, Fehler: GROSS=schlecht)
||/ Name Version Architektur Beschreibung
un linuxcnc <keine> <keine> (keine Beschreibung vorhanden)
un linuxcnc-dev <keine> <keine> (keine Beschreibung vorhanden)
un linuxcnc-doc <keine> <keine> (keine Beschreibung vorhanden)
ii linuxcnc-doc-en 1:2.8.3 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.3 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.8.3 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <keine> <keine> (keine Beschreibung vorhanden)
un linuxcnc-sim-dev <keine> <keine> (keine Beschreibung vorhanden)
ii linuxcnc-uspace 1:2.8.3 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.3 amd64 PC based motion controller for real-time Linux
This is the content of the ini:
# Erstellt von PNCconf am Wed Sep 14 18:39:56 2022
# Using LinuxCNC version: 2.8
# Änderungen an dieser Datei werden beim nächsten
# overwritten when you run PNCconf again
[EMC]
MACHINE = LinuxCNC-5i20-Axis
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G21 G40 G90 G94 G97 G64 P0.025
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_5i20.0
[HAL]
HALUI = halui
HALFILE = LinuxCNC-5i20-Axis.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
MIN_LIMIT = -0.01
MAX_LIMIT = 400.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
ENCODER_SCALE = 1000.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 1000.0
MIN_LIMIT = -0.01
MAX_LIMIT = 400.0
HOME_OFFSET = 0.0
[AXIS_Y]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 700.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 1000.0
MIN_LIMIT = -0.01
MAX_LIMIT = 700.0
HOME_OFFSET = 0.0
[AXIS_Z]
MAX_VELOCITY = 25.0
MIN_LIMIT = -100.0
MAX_LIMIT = 90.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 1000.0
MIN_LIMIT = -100.0
MAX_LIMIT = 90.0
HOME_OFFSET = 0.0
[SPINDLE_0]
MAX_VELOCITY = 2000.0
MAX_ACCELERATION = 300.0
STEPGEN_MAXVEL = 2500.00
STEPGEN_MAXACCEL = 375.00
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 1000.0
And this is what the console outputs:
cnc@LinuxCNC:~$ sudo mesaflash --device 5i20 --readhmid
[sudo] Passwort für cnc:
Configuration Name: HOSTMOT2
BoardName : MESA5I20
FPGA Size: 200 KGates
FPGA Pins: 208
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 33.3333 MHz
Clock High frequency: 100.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3500
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: StepGen
There are 6 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
3 1 IOPort MuxedQCount 0 MuxQ-A (In)
5 2 IOPort MuxedQCount 0 MuxQ-B (In)
7 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
9 4 IOPort MuxedQCount 1 MuxQ-A (In)
11 5 IOPort MuxedQCount 1 MuxQ-B (In)
13 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
15 7 IOPort MuxedQCount 2 MuxQ-A (In)
17 8 IOPort MuxedQCount 2 MuxQ-B (In)
19 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
21 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
23 11 IOPort StepGen 5 Step/Table1 (Out)
25 12 IOPort StepGen 5 Dir/Table2 (Out)
27 13 IOPort StepGen 4 Step/Table1 (Out)
29 14 IOPort StepGen 4 Dir/Table2 (Out)
31 15 IOPort StepGen 3 Step/Table1 (Out)
33 16 IOPort StepGen 3 Dir/Table2 (Out)
35 17 IOPort StepGen 2 Step/Table1 (Out)
37 18 IOPort StepGen 2 Dir/Table2 (Out)
39 19 IOPort StepGen 1 Step/Table1 (Out)
41 20 IOPort StepGen 1 Dir/Table2 (Out)
43 21 IOPort StepGen 0 Step/Table1 (Out)
45 22 IOPort StepGen 0 Dir/Table2 (Out)
47 23 IOPort None
IO Connections for P3
1 24 IOPort None
3 25 IOPort None
5 26 IOPort None
7 27 IOPort None
9 28 IOPort None
11 29 IOPort None
13 30 IOPort None
15 31 IOPort None
17 32 IOPort None
19 33 IOPort None
21 34 IOPort None
23 35 IOPort None
25 36 IOPort None
27 37 IOPort None
29 38 IOPort None
31 39 IOPort None
33 40 IOPort None
35 41 IOPort None
37 42 IOPort None
39 43 IOPort None
41 44 IOPort None
43 45 IOPort None
45 46 IOPort None
47 47 IOPort None
IO Connections for P4
1 48 IOPort None
3 49 IOPort None
5 50 IOPort None
7 51 IOPort None
9 52 IOPort None
11 53 IOPort None
13 54 IOPort None
15 55 IOPort None
17 56 IOPort None
19 57 IOPort None
21 58 IOPort None
23 59 IOPort None
25 60 IOPort None
27 61 IOPort None
29 62 IOPort None
31 63 IOPort None
33 64 IOPort None
35 65 IOPort None
37 66 IOPort None
39 67 IOPort None
41 68 IOPort None
43 69 IOPort None
45 70 IOPort None
47 71 IOPort None
Does anyone have any idea what the problem is?
