Re:5i20 + 7i52s + 7i37TA -> change the IO Pins
14 years 1 month ago #24061 by trilobyte
is it possible to modify pncconf t obe able to configure the io's matching to the SVST6_6_7I52S bitfile?
without pncconf it's ab bit tricky for greenhorns like me ,-)
BR
peter
14 years 1 month ago #24081 by cmorley
If Peter can supply the PIN file I will try to convert it to what PNCconf needs.
14 years 1 month ago #24117 by trilobyte
how can i supply the Pin File? I've only the bitfile from the link above.
BR
Peter
14 years 1 month ago #24131 by PCW
Heres the pin file:
freeby.mesanet.com/SVST6_6_7I52S.PIN
14 years 1 month ago #24145 by cmorley
Ok here is the XML file pncconf needs.
It must be put in the /lib/firmware/hm2/5i20 folder
You must be sudo to do that. (One way to do that is open a terminal and enter sudo nautilus )
File Name: SVST6_6_7i52S.xml
File Size:15.8 KB
14 years 1 month ago #24146 by cmorley
may be easier as a zipped file:
File Name: SVST6_6_7i52S.zip
File Size:702 B
Time to create page: 0.365 seconds
