PncConf wizard Max Acceleration nd Following Error
19 Oct 2012 19:07 #25445 by diegoroman17
Hi everybody,
I am using PncConf to configure my CNC Laser but in axis Motor/Encoder X, Y or Z configuration it only permit maximum acceleration = 10000mm/s^2. Is posible increment this?
Other question. That refer the parameters Rapid Speed Following Error and Feed Speed Following Error?
The following user(s) said Thank You: emad_ahmed2
20 Oct 2012 03:07 #25470 by cmorley
I can increase the max. but you'll have to wait for the next release.
What is a sensible max for laser machines?
In the mean time you'll have to hand edit the INI file.
Rapid speed following error is max error allowed while moving at max speed (eg. G0)
feed speed following error in max error followed while at feed speeds (eg G1 or G2 etc)
The faster you feed at the more error allowed.
Chris M
20 Oct 2012 15:43 #25487 by diegoroman17
In the present exist laser machine of 3G(aprox 30000mm/s^2) of maximum acceleration, even can be of 5G of acceleration(aprox 50000mm/s^2).
I don't understand, if I set G64 P0.001 this means that there is 0.001mm of desviation, then why feed error parameter? A error to rapid moves?
G61 (exact path mode) is not exact?
20 Oct 2012 22:48 #25513 by cmorley
ok I will up the max acceleration to 50000 mm/s.
exact is never exact :)
there is always following error, however small.
The following error settings dictate when linuxcnc will stop and throw an error.
The g64 settings is for the naive cam setting which is different.
This is the deviation of the code's actual end points vrs the 'cam's' adjusted end points.
while moving to these end points there still could be small following error.
if the following error gets too large linuxcnc will throw an error.
following error is small - deviation is usually a magnitude larger (AFAIK)
21 Oct 2012 00:32 #25519 by diegoroman17
Yes, nothing is exact :)
Now I understand, following errors in only to activate errors. Thanks my friend
21 Oct 2012 05:44 #25531 by cmorley
I pushed the fixed upper limit of acceleration - available on builbot now or in the next bug fix release....
21 Oct 2012 15:27 #25552 by diegoroman17
Thanks, I try it :)
Time to create page: 0.065 seconds
