PncConf 7i43 Axis Motor Test/Tune error
20 Oct 2012 05:21 #25475 by bjames28
PncConf 7i43 Axis Motor Test/Tune error was created by bjames28
Hello,
The motor test / tuning works well in PncConf with 5i20 cards, but Iit gives error messages with 7i43 cards.
like this : (....line 9097, in update_tune_axis_params halrun.flush() IOError [Errno 32] Broken pipe)
I suppose those error messages can be easily eliminated with little effort, making the motor testing very easy for 7i43 cards too.
If it requires a lot of work or rewriting hundreds of code lines then my estimation is wrong...:)
Of course I am willing to help in bug hunting.
Thanks for support in advance.
Regards:
James
I
20 Oct 2012 05:26 #25477 by cmorley
Replied by cmorley on topic Re:PncConf 7i43 Axis Motor Test/Tune error
Hey James.
Thanks for reporting.
I need to know a couple things...
first what version of linuxcnc are you using?
second if you run PNCconf in a terminal and get that message you will see the actual HAL error message, which will help pinpoint the fix.
cheers Chris M
20 Oct 2012 06:25 #25478 by bjames28
Replied by bjames28 on topic Re:PncConf 7i43 Axis Motor Test/Tune error
Hi Chris,
LinuxCNC version: 2.5.1-28-gea820a7
and the messages from console:
halscope: could not find thread: 'THREAD (null)'
halscope: could not set horizontal multiplier: 'HMULT 1'
halscope: config file 'autosave.halscope' caused 2 warnings
<stdin>:19: setp requires 2 arguments, 1 given
This was generated when I clicked on "Test/Tune Axis" button.
Later, when I click on "Enable" or "+" or "-" buttons then there is a popup windows with the messages like I mentioned, but nothing else comes up in the console.
Regards:
James
14 Nov 2012 16:29 #26576 by bjames28
Hi Chris,
Is this information is enough for debugging, or do I need to provide further infos?
Of course if there is another reason why there was no response, then please forget this message.
Regards:
James
15 Nov 2012 15:49 #26612 by cmorley
no this is probably all you can tell me. This report just fell through the cracks.
Thanks for reminding me.
Chris M
15 Nov 2012 16:01 #26613 by cmorley
OK I changed my mind can you send me your config pncconf file (not the config it's self)?
I really need to build a cable for my 7i43.... :)
Was this a stepper machine?
Chris
16 Nov 2012 01:50 #26639 by bjames28
Hi Chris,
This was a stepper config.
The link to the file: pncconf
I tried the stepper tune only on X axis, but I suppose the situation is similar with Y and Z too.
Regards:
James
Time to create page: 0.058 seconds
