I want to use a Mesa IO card
  • garymcrobertpdx
  • Premium Member
  • Premium Member
22 Dec 2012 09:13 #27942 by garymcrobertpdx
Replied by garymcrobertpdx on topic I want to use a Mesa IO card
Since I have five Step motors and 1 or 2 DC servo motors (they use step & dir input also)
perhaps the Mesa 5i25 with ether two of the 7i78 or two of the 7i76 daughter boards
would do the job for me.
If for some reason I should need a few more IO lines can the computer par port still be
used in conjunction with a Mesa board setup?
22 Dec 2012 09:24 #27943 by PCW
Replied by PCW on topic I want to use a Mesa IO card
Probably a 7I76 and 7I78 or 7I76/7I75 combo would do (and be cheaper than 2x 7I76)
There's no problem using a parallel port with Mesa hardware
(this is a feature of LinuxCNC, you can use pretty much any mix of hardware you like)
22 Dec 2012 09:29 #27944 by andypugh
Replied by andypugh on topic I want to use a Mesa IO card
Yes, no problem at all. As far as I know everything can work with everything.
I will point out that the 7i76 has terminals to connect a smart-serial device, (not sure if the 7i78 has, but I would expect so). Those are typically 48-pin IO devices, and some (like the 7i64) can switch serious volts and current.
  • garymcrobertpdx
  • Premium Member
  • Premium Member
22 Dec 2012 09:36 #27945 by garymcrobertpdx
OR could I use two 7i75 boards to output my step and direction signals
I presume the FPGA is the actual source of the step and direction output
and encoder inputs are also dealt with in the FPGA.
22 Dec 2012 10:21 #27950 by andypugh
Yes. There is one exception at the moment (the 7i73 has onboard quadrature counters) but otherwise stepgen and encoders run on the 5i25 / 7i43 / 5i23 class FPGA cards.
22 Dec 2012 11:58 #27952 by PCW
2 7I75s will do the only disadvantage is that they are unbuffered so you only get 3.3V signals direct from the FPGA (like using a parallel port directly) You can also use parallel port type breakout boards with the 5I25.
The 7I73 (and 7I69 and 7I70 and 7I76 and 7I77) have remote encoder counters (not in the FPGA) but these are mainly intended for MPG use as they have no index and they default to 1X quadrature mode (so 100 PPR MPGs generate 100 pulses per turn or 1 per detent) They are also limited to about 50 KHz count rate.
Time to create page: 0.056 seconds
