errors running PnCConf from terminal
- microsprintbuilder
- Thank you received: 4
18 Feb 2013 08:58 #30240
by microsprintbuilder
Replied by microsprintbuilder on topic errors running PnCConf from terminal
I have this exact error anyone know how to fix it?
- arvidb
- Thank you received: 159
18 Feb 2013 10:43 #30242
by arvidb
Replied by arvidb on topic errors running PnCConf from terminal
I had this error too. Chris explained how to fix it
here
. (Read the following message too.)
- Thank you received: 2164
19 Feb 2013 03:59 #30296
Replied by cmorley on topic errors running PnCConf from terminal
arvidb
Thanks for posting help - always nice when I read the forum and someone else has pointed out the solution, after they have been helped.
It's a great community.
Chris M
Chris M
19 Feb 2013 11:36 #30303
I opened the file and the indentations are all the same. Could it be something else.
also when I run the linuxcnc and try to enable I get :
joint 0 on limit switch error
joint 2 on limit switch error
I have lookd at the limit signals from the hal configuration window and watch them turn from yellow to red as they are tripped so I know they are working.
Thanks! in advance for your help
19 Feb 2013 11:47 #30304
ok so what's the error in pncconf? ( you can ignore the warnings )
or are you talking error in linuxcnc?
limit switch errors usually means u need to invert the inputs.
Chris M
Chris M
20 Feb 2013 03:37 #30332
I have a error pncconf when trying to enable servos as follows
File"usr/bin/pncconf",line 9334, in on_enableamp_toggled self.update_axis_params()
file "/usr/bin/pncconf", line 9304, in update_axis_params halrun.flush()
IOError:[Errno 32] broken pipe
So I am unable to test my servos in open loop
And when I run linuxcnc I get the following when I try to start:
20 Feb 2013 09:55 #30342
If you run PNCconf from a terminal, It will show more detail about the error.
from what info you have given I can't diagnose the problem. Those error message are very general.
As I said, the joint limit error are from the backward logic ( I assume the switches are not closed when the error occurs)
You can invert the logic in PNCcong on the page you selected the limit switches on, There is a checkbox
Chris M
Chris M
21 Feb 2013 02:48 #30384
OK I'll try that tonight. I'm not sure if I can go any futher. I was wanting to see if I had the amps wired right as they are the orignal GE and I didn't have and wiring diagram. I tried to run the amps with some jumpers wires and ended up smoking the z amp. I'm bidding on some AMC's. I used them on my first mill and they worked great. Hopfully I will have something in a couple days. I'll get back to you when I have everthing wired. thanks for your help.
26 Feb 2013 23:15 #30621
New amps showed up. I went and inverted the limits in PNCConf and that got rid of the Limit error however the servos are still not working. Ran out of time. Im going to download the 2.5 from the buildbot tonight to see if that helps. I do have one question pertaining to the servo enable switchs. My AMC amps are ground to inhibit and open to run. can the enable switch inverted?
- Online
- Thank you received: 5282
26 Feb 2013 23:24 #30624
Replied by PCW on topic errors running PnCConf from terminal
No, the enables can only be 'on' for enable
(otherwise they would have to be 'on' without power which is tough for an OPTO isolator)
I would use a small relay with a NC contact for all inhibit lines, driven by a 7I77 field output
Time to create page: 0.544 seconds
