parport only setup feature
14 Feb 2013 04:43 #30044 by alkeksibus
parport only setup feature was created by alkeksibus
hello !
I 've build a simple x-y-table with both axis driven by small dc motors in a gearbox driven by 2 vnh3sp30 h-bridges.
The motors have an incremental shaft encoder output (optical, 64 pulses per rev in ttl logic level ),
the h-bridges accept pwm and direction input.
All 6 wires ( x pwm out, x dir out, x position in, y pwm out, y dir out, y position in )
are successfully connected to the 0x378-parport ( pin 8, 4, 10, 7, 5, 11 )
of a standard pc with most recent linuxcnc installed (2.5.1 as of today).
Is it possible to use the pncconf wizard to build a basic machine controller for a closed-loop pid system using pwm for
motor speed control and shaft encoder as feedback ? It reads that at least one mesa card is necessary for setup,
but basically I don't understand if one has to have one ..
alex
14 Feb 2013 21:33 #30057 by andypugh
Replied by andypugh on topic parport only setup feature
No, it is specifically for configurig Mesa cards, rather than generic servo systems.
The good news is that there is already a sample configuration almost identical to yours. Look in the sample configs for the etch-servo config. This is a parport-only servo configuration for driving an Etch-a-Sketch.
You should be able to edit that to suit your application.
The following user(s) said Thank You: alkeksibus
Time to create page: 0.046 seconds
