problem with 5i25 configuration
- gandalf
22 Feb 2013 05:37 #30428
by gandalf
problem with 5i25 configuration was created by gandalf
Hi All,
I have a problem during the pncconf configuration of my 5i25.
When I arrive to the the X axis clicking on the Test Tune Axis button I got the error on the dmesg:
[ 521.147065] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 521.147097] hm2/hm2_5i25.0: invalid cookie, got 0x55AA4AFE, expected 0x55AACAFE
[ 521.147098] hm2/hm2_5i25.0: FPGA failed to initialize, or unexpected firmware?
the full log:
[ 521.099584] I-pipe: Domain RTAI registered.
[ 521.099588] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 521.099589] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 521.099626] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 521.099627] PIPELINE layers:
[ 521.099628] f81d5e20 9ac15d93 RTAI 200
[ 521.099629] c085cb20 0 Linux 100
[ 521.108191] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 521.108385] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 521.108387] RTAI[sched]: hard timer type/freq = APIC/6235800(Hz); default timing: periodic; linear timed lists.
[ 521.108389] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3391797000 hz.
[ 521.108391] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 521.108421] RTAI[usi]: enabled.
[ 521.121498] RTAI[math]: loaded.
[ 521.145508] hm2: loading Mesa HostMot2 driver version 0.15
[ 521.147044] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 521.147063] hm2_pci 0000:04:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 521.147100] hm2_5i25.0: board fails HM2 registration
[ 521.147106] hm2_pci 0000:04:00.0: PCI INT A disabled
[ 521.147109] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 521.182068] hm2: unloading
[ 521.202217] RTAI[math]: unloaded.
[ 521.209692] SCHED releases registered named ALIEN CF$Z8N
[ 521.209699] SCHED releases registered named ALIEN 2K52G5
[ 521.209701] SCHED releases registered named ALIEN RTGLBH
[ 521.209702] SCHED releases registered named ALIEN PUFUQK
[ 521.271669] RTAI[malloc]: unloaded.
[ 521.371305] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 521.372415] I-pipe: Domain RTAI unregistered.
[ 521.372462] RTAI[hal]: unmounted.
I tried also to rewrite the firmware using the latest mesaflash tools anf bit file from mesanet but I got always the same message about invalid cookie:
mesaflash ./7i76x2.bit write
Found mesa5i25 board
Checking cookie... ERROR: Invalid cookie: 55aa4afe, expected 55aacafe
I tried also to check the other switch:
mesaflash ./7i76x2.bit detect
PCI device 15 at bus/device/function 04/00/0
Vendor/Device/SSVendor/SSDevice: 2718/5125/2718/5125
Region 0: MEM 65536 bytes at f7c00000
mesaflash ./7i76x2.bit info
Checking file ./7i76x2.bit...OK
File type: BIT file
Design name: TopPCITargetHostMot2.ncd;UserID=0xFFFFFFFF
Part name: 6slx9tqg144
Design date: 2012/12/17
Design time: 13:34:24
Config Length: 340604
the full log:
File type: BIT file
- Online
- Thank you received: 5282
22 Feb 2013 07:50 #30430
Replied by PCW on topic problem with 5i25 configuration
Thats either a bad 5I25, bad PCI slot or dirty contact finger problem
I would try cleaning and reseating the card or trying another PCI slot.
If that does not work then the card needs to be returned for repair/replacement
- gandalf
22 Feb 2013 17:08 #30444
by gandalf
Replied by gandalf on topic problem with 5i25 configuration
Just tried another PCI slot and now it wokrs.
Great Mesa Electronics technical support! 10+
Time to create page: 0.056 seconds
