Pncconf Bug
- BigJohnT
- Thank you received: 1176
10 Mar 2013 23:32 #31183
by BigJohnT
Pncconf Bug was created by BigJohnT
Hi Chris,
We noticed a bug with Pncconf while chatting on the IRC. The [HOSTMOT2] section in the ini is not used by the loadrt hm2_pci line and that leads to quite a bit of confusion when trying to trouble shoot.
- Thank you received: 2164
11 Mar 2013 07:22 #31194
Replied by cmorley on topic Pncconf Bug
It's not a bug - it was a choice I made.
IMO It is easier to read / understand the HAL file if you can read the actual pin names rather then a substitution name.
Particularly if you have two Mesa boards.
I could get rid of the [HOSTMOT2] entry in the INI if you think that would help.
(it does say in the INI it is for info only)
Chris M
Chris M
- BigJohnT
11 Mar 2013 18:20 #31211
by BigJohnT
Replied by BigJohnT on topic Pncconf Bug
Having the [HOSTMOT2] section in the ini and not using it is buggy. If someone pastebin's their ini file on the irc or here and you make suggestions to change it assuming that it is used and it doesn't work everyone is scratching their head and wondering what is broken. Even though is says it is for info only it is not commented out so one naturally assumes it is used and wonders what that means...
I feel the same way now that I understand and know what the hal file is. I don't think first timers should have to look in several files for configuration settings even though I personally do it the same way as you for my machines.
13 Mar 2013 11:35 #31309
I will remove it from the INI file then.
- BigJohnT
13 Mar 2013 17:37 #31317
by BigJohnT
Thanks, can you just put a note in the ini file that the hostmot2 configuration is done in the hal file. That would give a newbee a heads up on where to look.
Time to create page: 0.096 seconds
