5I25-7I77 pinconfig startup errore
13 Mar 2013 21:51 #31331 by emad_ahmed2
5I25-7I77 pinconfig startup errore was created by emad_ahmed2
sorry i have the flowing error when i start linuxcnc after setup pinconfig and i cant find the cause of this problem
so if any one can tell me what is the problem
thanx
13 Mar 2013 23:26 #31339 by PCW
Replied by PCW on topic 5I25-7I77 pinconfig startup errore
you will probably have to post the complete dmesg here to see whats going on
13 Mar 2013 23:39 #31341 by emad_ahmed2
Replied by emad_ahmed2 on topic 5I25-7I77 pinconfig startup errore
Ok tell me how to post it and whar i found it
14 Mar 2013 00:20 #31346 by PCW
sudo dmesg -c
reboot
start failing program
dmesg > log.txt
post log.txt here
14 Mar 2013 08:39 #31373 by andypugh
Replied by andypugh on topic 5I25-7I77 pinconfig startup errore
The problem in the screenshot is probably due to a system crash on a previous attempt. Can you reboot, try again, and post the full output of dmesg? (as an attachment)
Time to create page: 0.080 seconds
