Getting started... Again?
- bogie6040
- Thank you received: 10
04 Apr 2013 09:14 #32254
by bogie6040
Replied by bogie6040 on topic Getting started... Again?
Andy, you had mentioned....
I would like to get going with the setup of the 7i73, my plan was to use this with an LCD or better yet an LED display (maybe have a PIC emulate an HD44780 controller) and if possible keyboard ( HALUI or userspace) if not I may just wire the "brains" of a USB keyboard to the keys I want to use for that...
I saw the thread 26138 and was wondering if there is anything newer or updated than whats in that post?
Also is everything I need already in LCNC after update to 2.5.2 or is there other files / firmware I need?
The 7i73 matrix keyboard is not easy to use at the moment, but I am working on a HAL component. (It works great with the 7i73 already, but I decided to make it work with any hardware and it took a step backwards)
- Thank you received: 5283
04 Apr 2013 10:00 - 04 Apr 2013 21:14 #32256
Replied by PCW on topic Getting started... Again?
You can get OLED character displays that are compatible with the 7I73s LCD interface.
New Haven NHD-0420DZW-AG5 for example.
Last edit: 04 Apr 2013 21:14 by PCW.
- Thank you received: 5005
04 Apr 2013 20:38 #32273
It is written and now part of the development branch.
It used to have to option of sending keystrokes to the OS, but I had to remove that part (not realtime-safe). It now only sets HAL pins.
www.linuxcnc.org/docs/devel/html/man/man9/matrix_kb.9.html
Replied by andypugh on topic Getting started... Again?
- bogie6040
06 Apr 2013 01:04 #32315
by bogie6040
So I can use the 7i73 to send keystrokes to the OS as the matrix_kb.9.html suggests - is that correct?
A slower thread is mentioned - are we talking like ~200 millisecond range for the debounce?
Also (separate project at work) - does anyone know if the 7i77 can be changed / forced to output actual
PWM and DIR signals instead or besides the +/- 10V analog, maybe on the field I/O?
If not is there a circuit I could build that would convert the analog to appropriate signals?
06 Apr 2013 02:49 #32317
If you have a 5I25 and want PWM output, a 7I77 will not work.
It is designed for analog outputs.
If you want PWM.Dir outputs, you will need to either use
the bare FPGA pins on the 5I25 or use a buffer card like the 7I85S
06 Apr 2013 03:13 #32321
No, that feature has been removed. I am not sure why the documentation hasn't updated.
It is probably possible to write a standalone userspace HAL component to turn the matrix_kb HAL output pins into keystrokes, and I do intend to have a go at that soon.
Time to create page: 0.169 seconds
