LCNC not starting my new configuration
- Thank you received: 5282
09 Apr 2013 10:29 #32453
Replied by PCW on topic LCNC not starting my new configuration
ScaleMAX should be set to the VFD's full scale RPM (at 10V)
Lets call this MaxRPM
MaxLimit should be set to MaxRPM
MinLimit should be set to -MaxRPM
- canner
09 Apr 2013 11:16 #32454
by canner
Okay, so the VFD shows 1800 RPM's at its max speed. So if I am doing this correctly then do I set the following:
ScaleMAX = 1,800
MaxLimit = 1,800
MinLimit = -1,800
I hope that I am understanding you correctly, but this still does not work. I think there might be something still not set up correctly within the drive perameters plus I need to put a meter on the pins and see what is coming in. Right now I can stop and start the drive, change direction but the speed control still does not work. It is either fast or slow but nowhere inbetween. Please let me know if my figures above should be different.
Replied by canner on topic LCNC not starting my new configuration
ScaleMAX = 1,800
MaxLimit = 1,800
MinLimit = -1,800
10 Apr 2013 01:55 #32496
Those look right. I would check that the spindle out
(TB4 pin 2) out is around 5V (relaltive to TB4 pin 1)
when you set a 900 RPM spindle speed
- canner
10 Apr 2013 06:38 #32507
by canner
Okay, it is working now, I just needed to restart axis after changing the ini file (seems kind of obvious). I need to reverse the directions so that they turn the right direction for the buttons on axis and on the ccw button the increase and decrease spindle speed buttons have the opposite effect but work correctly for cw. I will try a few things to get those going right. I think now I just need to get the encoder attached and working and I will feel good about starting to use it for work. There are a few other things that I want to do but it is not a rush on them. Thanks for all of the help so far.
Time to create page: 0.069 seconds
