Determining max velocity, max acceleration?
- customcutter
14 Apr 2013 00:36 #32693
by customcutter
Determining max velocity, max acceleration? was created by customcutter
Going by the Getting Started Manual V 2.5. If I'm reading it correctly, I should set the acceleration at 2 "/sec, and the velocity near what I hop to attain.
I set the velocity at 100 "/min, and tested. No problems, so I increased the velocity. I kept increasing at 10-20% until I reached 3000 "/min. Still no missed steps while I was pushing back against the table. I decided to stop there, as it seemed an insane number. I then started working on the acceleration value, and increased it to 500 IIRC, before encountering missing steps. Decreased to 350, and still missing steps. Decreased to 200 and still missing steps.
Finally decided to start over, I put in 250"/min as the max velocity, and 15"/sec as the acceleration. It was missing steps, so I backed down to 10"/sec on the acceleration and everything seems fine.
Does this sound reasonable???
thanks,
Ken
thanks,
Ken
- ArcEye
- Thank you received: 758
14 Apr 2013 16:20 #32721
by ArcEye
Replied by ArcEye on topic Determining max velocity, max acceleration?
Hi
Most people seem to set their velocity and acceleration far too high for what are comparatively low power motors.
Two factors to consider are that acceleration is not nn"/sec it is nn"/sec/sec;
also the figures in the .ini file are in units per second. That works fine for acceleration but when looking at velocity you need to multiply the figure by 60.
My Nema34 12Nm geared stepper powered turret mill, has axis MAX_VELOCITY of 25mm/sec (1500mm/min) and MAX_ACCELERATION of 12mm/sec/sec
It never misses a beat and can be left unattended for hours
Compare your figures by multiplying them by 25.4!
Another consideration is that you should set the MAX_LINEAR_VELOCITY under the [TRAJ] section to approx 20% higher than the individual axes to ensure co-ordinated moves can be brought off.
I don't know what machine you have, the time when steps are lost in real world machining are normally at high speed when the torque is lowest. A quick G00 retraction on a lathe at the end of a heavy cut is a favourite.
- BigJohnT
- Thank you received: 1176
14 Apr 2013 19:59 #32723
by BigJohnT
Yep, 250 IPM is 4.16 IPS and 10 IPSPS is about double if not a tad higher.
IPM = Inches Per Minute
IPS = Inches Per Second is what is used in your ini file
IPSPS = Inches Per Second Per Second for acceleration settings
Where in the Getting started manual does it say to use 2 IPS for acceleration? If it does read that way I need to fix it.
Replied by BigJohnT on topic Determining max velocity, max acceleration?
thanks,
Ken
- customcutter
15 Apr 2013 03:44 #32731
by customcutter
Replied by customcutter on topic Determining max velocity, max acceleration?
John:
Just typing in shorthand, I guess. I thought everyone would understand. It is 2"/sec(squared), or 2"/sec/sec.
I guess on a "technical" forum, I should try to be more technical.
Ken
Ken
