USB joystick configuration
  • PKM
  • PKM's Avatar Topic Author
  • Premium Member
  • Premium Member
02 May 2013 15:24 #33514 by PKM
USB joystick configuration was created by PKM
Hello,
I'm trying to configure my cheap wireless joypad with PnCConf
I did "Add device", then "USB Gamepad" was found (and pins change values in "Test device" when buttons pressed.
But how do I assign the pins to X+ X- etc? It seems natural to put cursor in the field and press a joypad button, but nothing happens.
Also, can I switch between analog and digital control?
03 May 2013 03:33 #33543 by cmorley
Replied by cmorley on topic USB joystick configuration
If you click the help button while on the external controls page, it will explain what you must do.
The following user(s) said Thank You: PKM
Time to create page: 0.050 seconds
